Fit the rollers with the spacer they came with.
Assemble and torque up to 60 lb/ft.NOT 150. The nut and thread will let go...
Torque is determined by CV type, not bearing type.
If they are loose when rocked, the hub centre web is worn a bit.
Put dial gauge on end of shaft and measure endfloat.
Then remove spacer and surface grind (.002" + endfloat) off it. Refit it- should be right.
The should be a slight drag when assembled and torqued up, but it should not feel jumpy or jerky.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
