It is currently Sun Jul 06, 2025 10:31 pm
PostPosted: Wed Mar 01, 2006 9:04 am
Has anyone fitted one of these to an Australian built mini. If so was it easy to do or a pain in the arse.
Pete
PostPosted: Wed Mar 01, 2006 12:56 pm
These clash with the bonnet hinges on Morris minis. The rear most bracket (top of your photo) bolts through the firewall in the groove where the bonnet hinge mount brackets live in a morris. On Rovers, the bonnet hinges were spaced further apart. So, on a Morris, they are a pain in the butt.
Connection to pedal box is easy and brake piping is simple too. A vacuum take-off from your manifold is needed.
I can't give you any info on Clubbies, sorry.
M
PostPosted: Wed Mar 01, 2006 1:21 pm
Thanks for the info.
Pete
PostPosted: Wed Mar 01, 2006 2:08 pm
M
should be right on a clubbie then, cos the hinges are in the same place as on a rover.... doesn't help a 68 deluxe tho...
PostPosted: Wed Mar 01, 2006 6:32 pm
I'm thinking the top bracket on the booster could be modified to make to fit without fouling on anything.
Pete
PostPosted: Wed Mar 01, 2006 6:53 pm
It can, they do retro-fit quite easily.
All is needed is a "slot" for the bonnet hinge to drop down into when the bonnet is closed.
I know that you stole that pic from Brickworx's ebay, cos i took the photo.
If you bought one, i'm sure you could request one that has already been converted for a Morris. (for a small extra fee :P )
PostPosted: Wed Mar 01, 2006 7:15 pm
Yes willy that is were the pic is from :lol:
I am seriously thinking of doing this but will have to wait for some money to fall into lap.
Pete
PostPosted: Wed Mar 01, 2006 7:24 pm
I'm hearing ya mate! :lol:
