It is currently Thu Jul 03, 2025 11:45 am
PostPosted: Sat Dec 24, 2005 8:19 pm
Hey guys,
Just had my Brake servo delivered (non remote) Due to clearence isses i need to find a diffrent master cylinder setup with the brakelines exiting on the right hand side of the master cylinder instead of the left,
Ps, It is a Disc/ Drum setup
If anyone knows of anything could you let me know pls,
Regards,
Ash
PostPosted: Sun Dec 25, 2005 8:03 am
hi ash,
I also had clearance issues with my brake master. Im using a twin line late model one and had to weld 2 new lugs on the base of it to spin it around 90 degrees to clear the inlet manifold.
Why are you having clearance issues? what motor you putting in?
1974 Moke - 998cc
PostPosted: Sun Dec 25, 2005 8:33 am
B16A Vtec - It is a VERY tight fit between the dizzy and master cylinder, have looked at going to a Coil on plug setup but i think it will be cheaper and easier to find another master cylinder
PostPosted: Sun Dec 25, 2005 9:21 am
Have you got a picture of it? you sure its not the clutch master in the way? i thought the dissy on the b16a was closer to the clutch master?
Here is a pic of a honda mini, he is using a mazda master with a relocated reservior.
1974 Moke - 998cc
PostPosted: Sun Dec 25, 2005 9:48 am
Is that charlie's super min
