It is currently Mon Jun 23, 2025 12:18 pm
PostPosted: Sat Aug 28, 2004 4:29 pm
Hello all,
Wondering if anyone can tell me if the brake and clutch master cyliner are interchangable? Or is there a mod required?
Thanks.
WHAT THE!!!
PostPosted: Sat Aug 28, 2004 5:01 pm
Yeah, well.... it depends.. :wink:
Most Minis have a 0.700" bore brake master cylinder (except early 850, and 998 Cooper)
Most Minis have a 0.750" clutch master cylinder.
If using `tin tank' MCs the flanges are different orientation between clutch and brake.
Brake MCs have a slow-return restrictor valve in top, clutch ones don't.
If using plastic tank cylinders (Lockheed/PBR) the 0.700 brake will work as a clutch one, but you will get less clutch stroke to release the plate, clutch will tend to drag.
So.... whaddya wanna do?? 8)
PostPosted: Sat Aug 28, 2004 5:26 pm
MOST of the ones i recondition seem to be the wrong bore for the application, and do/dont have valves where they should/shouldn'tt... I have a feeling my clutch one is incorrect....
G
--Insert legal disclaimer here--
PostPosted: Sun Aug 29, 2004 1:02 pm
Hey thanks guys
just doing a restoration and have these two master cylinders, they both fit on either side, wern't sure which went were.
I will just have to pull them apart and measure them up.
Appreciate the info thanks.
Den
WHAT THE!!!
PostPosted: Sun Aug 29, 2004 2:27 pm
On the Lockheed/PBR plastic tank ones, the bore is often marked on the body. :wink:
