Well, most here would probably think it's a waste, being in a Moke but this isthe specs I have, built 11 years ago this October and still going strong;
73.5mm Bore offset bored to suit 74mm
Nitrided crank
Omega shallow dish pistons, (due to machining mistake I did have 380lb compression)
Lightened rods
Balance to 1100s Flywheel to 10K (never used above 6.5k, peggs speedo)
Enlarge oild feed thru block to all main bearings (still holds 80psi)
Ported head (unfortunately the original cracked 3 yrs ago, still have above average head in use)
Fed via 2 1-1/4 SU's (torque produced via fuel starvation. Run in on M needles, now AH2)
Hi-Torque Cam, basic std duration, higher lift.
Since then, due to age and replacement;
Belt timing kit
Alloy radiator 2" core
Also
Adjustable lower arms, castor bars & HiLo's (set at 6deg Neg Camber - good on the Black Spur)
Yes I have all this in a Moke, call me insane if you like, it's probable true
