I have been told/read that it can be done, and since I got it for free, it's cheaper than buying a used 1275. So I'm gonna do it. Plus I don't want to find a 1275 for a Mini.
-The head is a 12G1316 cast. Needs to be completly rebuilt though, but no big deal.
-The block is 12V/6712/L21855 cast. The link below was from a earlier thread, and a few of you said I have to cut something off the block and find a 1275 crank for it.
Here's a picture for reference. I'm assuming the 'end cap' that needs to be cut off is the part closest in the picture. Are there any other things. I'm going to need to know before this goes to the machine shop?
Also, I plan to put a supercharger on this. Do any of you know what the stock compression ratio was for these engines? I just need to get an idea, as I have heard they are low compression engines.
