It is currently Mon Jun 30, 2025 1:15 pm
PostPosted: Thu Sep 15, 2005 6:43 pm
I need some info. from someone that has these. REAR DISKS
1. Disk diameter
2. hub width.
3. disk width
4. brake surface wisth on disk
Thank you for your help.
PostPosted: Thu Sep 15, 2005 9:08 pm
don`t think there`s that many people here who have a money tree to be able to afford them ;-)
Make em yourself
easy enough to fabricate from 2nd hand stuff from the wreckers & whip up a billett alloy rear hub for it easy-peasy
i used to make alloy rear hubs, but only stock looking ones,,,been meaning to set up for a disc flange on the back of the next set i machine up tho
PostPosted: Thu Sep 15, 2005 10:09 pm
I've got spare discs floating around here for the front of a car. How does the handbrrake usually connect up with discs?
I'm not going to do a conversion, but I wondered if it can be done.
PostPosted: Fri Sep 16, 2005 4:41 pm
I'm going to build my own, with a hydro hand brake on a seperate system. Similar to rally cars. I plan to use a motorcycle rotor, but would like to know what diameter the KAD ones are. I think a 6-8" -1/4" rotor will do.
I believe the KAD disks have a cable hook up as well, which I won't be able find I don't think.
There are a few people I have emailed, but no replies yet.
TheMiniMan- Do you know the dimensions off hand for the inner cavity where the bearings sit? I still have to press out the bearing on my hubs, but if I could just get the dimensions, that would save a little time.
