Chris wrote:
Stuwey_LS wrote:
I want to try a late model Honda Civic one on the the drivers side, they are much smaller, and with Alloy core, work much more efficiently.
Don't you believe it. Copper is far and away better than any aluminium radiator. It is heavier than aluminium, but works better.
And unlike copper, aluminium corrodes badly inside with age which further stuffs up the heat transfer.
Most Ford taxis here in Sydney fling the crap alloy 2 core rad and fit a copper/brass 3 core. Way better.... I had one in my tow car.
Car makers went to alloy rad cores with plastic tanks for 1 reason only, to save $$$.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
