It is currently Mon Jun 30, 2025 12:02 am
 Post subject: re-13 lift
PostPosted: Wed Jun 15, 2005 12:06 am
just wondering what the full valve lift of the re-13 cam is?
i have just bought a set of minispares forged 1.5 ratio rockers (actual ratio is 1.58 i'm told)
my valve springs are good for .490" and 8000rpm lift just wanna do the calculations and find out if i am going to run into coil bind dramas or not.
cheers steve
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Wed Jun 15, 2005 7:05 am
Look in this thread. http://www.ausmini.com/forums/viewtopic ... ht=rockers
ON p1 I posted lift figures for an RE-13 cam, with S forged rockers, Toyota Corolla (1.46) rockers, and MS forged 1.5 rockers.
Your lift is 0.450", those springs etc will be fine, that's what I'm running. :wink:
Set rocker clearance to .020" to start with- after it's run in, try reducing clearance to .018".
