It is currently Fri Jun 20, 2025 5:05 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: 123 electronic dizzy
PostPosted: Sun Jun 26, 2022 6:33 pm
Can I share my recent electronic distributor experience with the forum?
Soon after I purchased my 1972 1100 Clubbie I invested in an aftermarket electronic distributor with Hall effect pick up. The whole distributor not just the pick up. This was on the basis that I had convinced myself that a purely electronic contrivance with no moving parts was bound to be more reliable. Last week end while motoring in Camden, 50+ kms from home in Sydney, the car stopped without warning in the middle of town.
I quickly discerned that the problem was no spark and the likely culprit was the electronic distributor. Having managed to park the car I waited for the bus to get home. A beautifully restored battleship grey Mini van flashed past but the driver ignored my frantic waves.
I had removed the distributor held in place only by the one machine screw so I could match it to whatever I had at home, maybe what it replaced. On the train I had plenty of time and inspected the offender. Inside I found both wires to the pick up had been rubbing against the rotating central shaft and both had nearly worn through. No doubt the source of a short circuit.
At home I soldered in some new leads and anchored them with cable ties to stop it happening again. The car started enthusiastically at the first turn of the key.
I will leave the old mechanical distributor in the boot in case of another emergency.
PostPosted: Wed Nov 30, 2022 3:30 pm
I put an old Nissan Pulsar dizzy in my 850. Didn't take long to modify, couple of hours work
Cheap and easy fix
'64 850 (in pieces)
'71 Landcruiser SWB 327 Chev 'The Beast'
2008 Golf GTI
