It is currently Sat Jun 28, 2025 2:07 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jun 08, 2005 12:57 am
yeah the steering wheel is supposed to be like that, because you sit to the right of it, and it angles towards you like that.
wierd hey..
and they cut that so they could get warm air on to their chilly face and hands instead of their feet.
quite silly to do that.
 Post subject: steering wheel
PostPosted: Wed Jun 08, 2005 12:28 pm
all mini steering wheels come out on an angle however the short shafts dont look as bad as the long shafts
regards,
opalmini
PostPosted: Wed Jun 08, 2005 12:54 pm
Steering column looks fine to me - normal Mini angle. :)
When a fresh air heater was fitted under the bonnet, that plate on the firewall would have been removed and replaced with a fitting for the tube from the heater to clamp onto.
The metal plate/box/thingy on the inside firewall which has been hacked about was fitted to all Aussie Non-Cooper Minis from 65ish to 71 (when the K with the Clubby heater canme along). It's purpose was to direct incoming air from the (optional) heater onto the screen - drivers side only! A flap under the dash stopped air from flowing around the driver's ankles.
When a heater was fitted (by the dealer or aftermarket) the heater box was simply bolted in under the bonnet, and the flap was added under the dash. The dash trims did not have to be removed to fit ducting to the screen, so teh whole process was pretty simple.
I would guess that someone has fitted your car with a Cooper or Clubman heater (under dash box, demists both sides of screen). When fitting these heaters the welded box ducting has to be cut away to allow the Clubman/Cooper/Moke ducts to bolt to the dash top. When I removed the box in my van I carefully drilled out the spotwelds and pulled it out. Soneone has done a very dodgy job on this one!!
Cheers.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Jun 08, 2005 4:39 pm
I need a demister for a blue slip, well that blows....
Best i find that number of that guy that gives the dodgy blue slips :wink:
The heater is just an eye saw sitting there in the middle of the car
Life's a garden.... Dig It!
PostPosted: Wed Jun 08, 2005 5:09 pm
You need a demister for blue slips I don't know that that nessicarily means you need a heater. ie it may be sufficent to just have air blowing up through the vents.... don't know but I think it was disscussed before a little bit can't remember what the out come was. :D
Roads need more corners
PostPosted: Wed Jun 08, 2005 6:10 pm
min13k wrote:
gordo just remember you have to have a demister for bluslip
makka
Only if the car was built with it. If the car has a compliance plate you may have to have one.
PostPosted: Wed Jun 08, 2005 6:49 pm
My Heater not blowing hot air and still got past RWC here in vic. Is a 74 not sure if any ADR's apply to demisters though chech on RTA website as to specific regs up there. We can Check them online down here!
PostPosted: Thu Jun 09, 2005 5:35 am
Or maybe someone tried to get some more room for a tacho there in a custom dash or something.
