It is currently Thu Jul 03, 2025 10:21 pm
 Post subject: R53 Timing Chain Noise
PostPosted: Tue Oct 17, 2017 6:05 am
Hi All,
I have a 2002 JCW with 180kms. It makes a noise at low revs, but high load (in 5th or 6th pulling up a hill) like a high pitch ticking that is not consistent and when you back off the throttle it drops away.
it sometimes makes a little rattle on a cold morning also. I replaced the tensioner a few months back and it helped a bit but I wonder if the whole job needs doing.
does this sound like timing chain?
Thanks
1964 Mini "850" - Thats what the boot says anyway.
PostPosted: Tue Oct 17, 2017 6:14 am
First noise from your description seems like pinging (engine knocking / pre detonation). Normally from having low octane or poor quality fuel or too much timing advance. It can cause big engine problems
PostPosted: Tue Oct 17, 2017 9:18 am
Definitely get it checked. As Tim suggested sounds like knocking, but with a modern car they normally have a “knock sensor” to automatically adjust timing and protect the motor from damage. Perhaps this is faulty?
PostPosted: Tue Oct 17, 2017 9:21 pm
Thank you. yes, that may be the issue. I put standard fuel in last time I filled up due to not having high octane stuff at the pump. that could be the issue.
Thanks
