It is currently Wed Jul 02, 2025 4:10 pm
 Post subject: 2005 R53 MCS
PostPosted: Tue Sep 20, 2016 12:20 pm
Hi All,
Am looking to purchase a second hand MY 2005 / 2006 R53 MCS.
Price range $10-$15k.
Will probably do plug and pulley upgrade and cat back exhaust.
Any concerns I need to consider with this model as a second hand vehicle?
Z
Zulu...
1967 mini Cooper S
 Post subject: Re: 2005 R53 MCS
PostPosted: Tue Sep 20, 2016 1:10 pm
I have had an 05 for the past 4-5 years & it has been super reliable.
Keep an eye for leaking plastic header tanks, noisy power steering pumps (they are generally noisy), check the power steering pump fan works by turning on the AC, this will trigger the fan.
The low speed fan relay can often go, check by turning on the AC & the low speed fan should come on.
Thermostat leaks.
Harmonic balancer failure can be common at this age.
Less common is a noisy supercharger, more specifically the gears that drive the water pump. At either end of the supercharger there are two small oil reservoirs, the seal can fail at the clutch end of the supercharger draining the reservoir & then the two drive gears for the water pump destroy themselves, you won’t see an oil leak as the oil gets sucked into the supercharger)
Despite the list above and contrary to what others might say, they are a great car.
(..... I should declare my 05 MCS is for sale, however in NSW)
PostPosted: Tue Sep 20, 2016 2:15 pm
Awesome info.
Zulu...
1967 mini Cooper S
PostPosted: Thu Sep 29, 2016 12:00 pm
if your interested in going the turbo route, we have just listed ours for sale. very very well looked after car.
http://www.gumtree.com.au/s-ad/nuriootp ... ialbuttons
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Sep 29, 2016 1:20 pm
I work in Nuri!!!! But it's my last day before 2 weeks leave!
Zulu...
1967 mini Cooper S
PostPosted: Sun Oct 02, 2016 4:49 pm
There you go, get in touch if your interested in a look. You have probably seen it getting around then!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Oct 02, 2016 7:28 pm
I've seen one up there like that and there was a younger woman driving it. Not sure if that's yours but I've Always admired it.
Zulu...
1967 mini Cooper S
PostPosted: Mon Oct 03, 2016 8:08 pm
Young blondie? That's my wife ha ha
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Oct 03, 2016 10:47 pm
The younger woman is his so stop admiring it. :)
PostPosted: Tue Oct 11, 2016 7:45 pm
lol.
If it's still available after the 17th I'll PM you as I'm back in the valley then.
Zulu...
1967 mini Cooper S
PostPosted: Tue Oct 11, 2016 11:52 pm
be careful
have been informed by a reliable source most parts for any bmw mini after 10 years old are becoming very scarce ,if not non existent.
virtually not supported at all.
this may be true or not. but would be worth investigating.
65 panel van Sprog
73 panel van Iggy
PostPosted: Wed Oct 12, 2016 5:17 am
Crikey! Is this true!
Zulu...
1967 mini Cooper S
PostPosted: Wed Oct 12, 2016 9:01 am
have been told anything pre 2004 good luck with your projects .
and this was from someone in the trade .
65 panel van Sprog
73 panel van Iggy
PostPosted: Wed Oct 12, 2016 7:38 pm
Bugger
Zulu...
1967 mini Cooper S
PostPosted: Thu Oct 13, 2016 10:23 am
I'm sure she loves the attention!
absolutely be in touch. you wont find a better one than this.
interesting comment regarding getting parts. I have a 03 cooper s which I'm building as a hillclimbr/race car. and have had no issues getting anything. perhaps that's a bmw specific thing, ie bmw don't keep the parts?(I know after a point in time, bmw credit the dealers for parts and essentially write them off. perhaps that's the 10 year thing?)
I have gotten stuff out of America etc easy as. and minisport in Adelaide has a huge range of parts.
look forward to hearing from you!
jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
