BINI Specs? https://ausmini.com/forums/viewtopic.php?f=4&t=48430 |
Author: | bigtez [ Sun Dec 14, 2008 6:57 pm ] |
Post subject: | BINI Specs? |
Where is the best place to find accurate specs on MINI's from 2002-2005? |
Author: | Harley [ Sun Dec 14, 2008 7:21 pm ] |
Sales brochures. What do you want to know specifically? |
Author: | bigtez [ Sun Dec 14, 2008 7:36 pm ] |
Basically want to compare the differences between the different years and what was upgraded on the newer models. |
Author: | mcsmik [ Sun Dec 14, 2008 9:18 pm ] |
Check out the FAQ page on MINI2.com all the details are there ![]() |
Author: | brett [ Thu Dec 18, 2008 9:18 pm ] |
bigtez wrote: Basically want to compare the differences between the different years and what was upgraded on the newer models.
the R53 came in in 2004, with 3kw more power in the Cooper S and I think the Cooper stayed the same, plus the R53 seemed to be built better with better quality finishes BUY A R53 |
Author: | bigtez [ Fri Dec 19, 2008 10:30 am ] |
Next Q? Can you put a towbar on them? |
Author: | Harley [ Fri Dec 19, 2008 12:03 pm ] |
Not on a cooper S because the factory fit the exhaust with a centre exit. The non charged car can tow something if you really want, but the gearboxes dont last under the cars own weight let alone something else. ![]() |
Author: | bigtez [ Fri Dec 19, 2008 12:50 pm ] |
Thought that might be the case. |
Author: | brett [ Fri Dec 19, 2008 6:09 pm ] |
yes you can fit a tow bar to a cooper S, you need to move the centre pipes to to either side. ( PM kenhenry on www.mini2.com he has done it!) |
Author: | mcsmik [ Fri Dec 19, 2008 10:46 pm ] |
bigtez wrote: Next Q? Can you put a towbar on them?
Yes you can, MINIFINI sells a kit for the S. ![]() |
