Service Manual for 2004 Cooper S https://ausmini.com/forums/viewtopic.php?f=4&t=48414 |
Author: | GAT51 [ Sun Dec 14, 2008 10:37 am ] |
Post subject: | Service Manual for 2004 Cooper S |
Hi, has anyone got an electronic copy of the BMW Service Manula for my Cooper S, or knows where I can get one?? Cheers John |
Author: | xplosion77 [ Sun Dec 14, 2008 6:15 pm ] |
do you know what sercive it is up to |
Author: | GAT51 [ Sun Dec 14, 2008 6:30 pm ] |
It's up to 24000 but I really want a manual that shows engine componets etc like a haynes, or TIS. Cheers John |
Author: | xplosion77 [ Mon Dec 15, 2008 6:27 pm ] |
i dont think i would be able to get u the hole tis program but i am able to get some info on repairs for anything u need |
Author: | GAT51 [ Mon Dec 15, 2008 8:33 pm ] |
The engine light comes on at the moment and BMW tells me this is the air sensor clogged. BMW says just keep running tanks of fuel through and it will clear itself !! I would like to find it remove, clean and replace. At the same time I would like to change the air filter. Anything that helps me do this would be appreciated. Cheers John |
Author: | mcsmik [ Mon Dec 15, 2008 11:55 pm ] |
What model is your MCS? R53 or R56? If the garage can tell you what the fault code is then you can verify the cause of the problem. A full list of codes can be found on MINI2 http://www.mini2.com/forum/faults-fixes ... codes.html This thread on NAM might be of interest http://www.northamericanmotoring.com/fo ... ensor.html |
Author: | GAT51 [ Tue Dec 16, 2008 2:52 pm ] |
Build plate says R50 11/04 Cheers John |
Author: | xplosion77 [ Tue Dec 16, 2008 6:06 pm ] |
are you talking about the o2 sensor that is on the exhast system?. they are ok at fitting but not the best without a hoist, as its easier to get at the sensor if it is up in the air. if it is the correct part i am talking about email me with the last 7 numbers of your vin for your car and i can email you back the instructions my email is [email protected] |
Author: | GAT51 [ Wed Dec 17, 2008 7:57 am ] |
The last seven are TK75644. Cheers John |
