It is currently Fri Jun 20, 2025 11:58 pm
PostPosted: Thu Nov 02, 2006 7:26 pm
goddamit stop nagging me woman. havent i answered your question before?
bmw must be at least 1350kg in weight, if it must tow a 900kg caravan
:D
Inconspicuously Conspicuous
PostPosted: Thu Nov 02, 2006 7:31 pm
Im a woman its my job :P
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Thu Nov 02, 2006 7:47 pm
Don't ask the forum, you will only get wrong answers!
The NSW rules can be seen at Towing Trailers
I am sure that Vicroads will have something similar.
The most important bits are...
TOWING RATIO REQUIREMENT
The loaded mass of the trailer must not exceed the lesser of:
Rated capacity of the towbar and tow coupling.
Maximum towing capacity of the vehicle.
Maximum carrying capacity of the trailer.
Maximum rated carrying capacity of the tyres.
If the vehicle manufacturer has not specified the maximum towing mass, the maximum towing mass is:
One and a half times the unladen mass of the towing vehicle, provided that the trailer is fitted with brakes which are connected and in working order, or
The unladen mass of the towing vehicle if the trailer
does not require brakes
PostPosted: Thu Nov 02, 2006 9:06 pm
Check with the manufacturers. They should be able to tell you.
I'm pretty sure the limit is 500kg max but don't take my word for it. I doubt it is anywhere near as high as 900kg.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Nov 02, 2006 9:29 pm
Iv`e heard that people are having trouble just getting a tow bar firtted to the late Bimmer MINIs for some reason ?????
check with your local tow bar fitting guy first & see which way to go from there mate
PostPosted: Thu Nov 02, 2006 10:34 pm
I have a MINI brochure thing in front of me.
A Cooper is rated at 650 kg max @ 12% gradient, a cooper S is not rated.
PostPosted: Fri Nov 03, 2006 9:51 pm
Locally, there is no towbar option for the Cooper S as the exhaust is a centre exit.
There are options in the US. Alas the towing capacity is low as indicated above.
Hope this helps.
Chris
