It is currently Sat Jun 21, 2025 6:51 pm
PostPosted: Fri Sep 01, 2006 5:26 pm
well i just bought a set of bini taillights from ausminis4u and now the next issue is on hand... anyone know what goes to each pin in the plug for the back of em? seeing as i have a 78 clubby i cant just plug the new lights in and i'm not sure if i should just start testing them with a battery incase i damage the circuit board on the back of them... i'll prolli just start playing with them anyway but if anyone knows what should be on each of the 5 pins, it would help alot....
cheers.
PostPosted: Sat Sep 02, 2006 8:37 am
just get a 9v battery and start hooking wires up. the worst u can do is blow a bulb. you should be able to trace the wires to where they go
