It is currently Fri Jun 20, 2025 1:26 pm
PostPosted: Mon Feb 03, 2014 6:17 pm
Hi all. Does anyone know how to remove the A Pillar covers on the Cooper S. The problem I'm having is gaining access to the screws holding it on. I'm guessing I have to remove some of the trim. Any help would be greatly appreciated. :D
PostPosted: Wed Feb 12, 2014 7:51 am
Its pretty easy, the screws are under the rubber window seal. Pull it back and undo the screws, the cover should pop off. I did this when the windscreen had to be replaced on mine.
