https://ausmini.com/forums/
1:32 Scale Mokes
https://ausmini.com/forums/viewtopic.php?f=28&t=83298
Page 1 of 2
Author:  Thorlek [ Tue Oct 29, 2013 8:35 pm ]
Post subject:  1:32 Scale Mokes
Hey All,
Does anyone know if there are any 1/32 scale Moke's out there?
I can only find 1:64 and 1:43 in my searching.
Thanks!
Author:  Racing Green [ Tue Nov 12, 2013 11:46 pm ]
Post subject:  Re: 1:32 Scale Mokes
TVC-15 moke kits are 1:32. Around 140€ and impossible to find
Author:  Thorlek [ Wed Nov 13, 2013 8:51 am ]
Cheers for that, i'll keep my eyes out, but i wont hold out too much hope if thats the case.
I've seen some WWII jeep kits which could probbaly be converted into a moke with a bit of time and patience, maybe i'll do that.
All those years of table top war gaming might finally pay off for my mini obsession now :-P
Author:  simon k [ Sat Nov 23, 2013 3:51 pm ]
I could scale one of these up for you.... this is about 7cm long, how long would a 1:32 scale be?
Author:  Thorlek [ Sun Nov 24, 2013 7:05 pm ]
Nice! Is that 3d printed?
Im actually after the 1/32 scale model so I can convert it to a scalextric car
It would need to be hollow and have no wheels for that to work
Author:  simon k [ Mon Nov 25, 2013 10:31 am ]
that'd be easy to do... much easier than making a whole car. Give me a wheel base (centre of axle to centre of axle) and I'll resize it, then we can hollow it out and make some mounting points for your chassis etc.
and yep, 3d printed
Author:  grey 64 [ Mon Nov 25, 2013 1:09 pm ]
Was in Sydney over the weekend and stumbled across 2moke models in a retro shop. They were old dinkys in pretty ruff condition, the wanted $35 for both. I left em there. Also had morris 1100, Hillman imp and mini superfast model all in ruff condition between $30-$40.
Author:  LeylandMiniPhil98 [ Sat Nov 30, 2013 4:33 pm ]
and yep, 3d printed
Hey simon, how big could you scale one of those up to?
Author:  simon k [ Sun Dec 01, 2013 7:57 pm ]
AustinMiniMan98 wrote:
and yep, 3d printed
1:1 ?? :lol:
I get them printed by shapeways.com, the material is costed by cubic centimeter, so the bigger you go the more it costs. That one in the white plastic was about $30.
To make one for a scalextric could be reasonably cheap because I imagine it wouldn't need a floor etc. and could be pretty lightweight
Author:  LeylandMiniPhil98 [ Sun Dec 01, 2013 9:15 pm ]
I'd like one about 1:24 probably. Much easier than converting one from a jeep or vw thing. Then i could just add detail by carving it out, i have a small modeling drill, and adding parts from a model mini and that sort of thing.
Author:  simon k [ Sun Dec 01, 2013 9:54 pm ]
1:24 scale etc means nothing to me - I need dimensions, measurements, facts!
open this pdf and you'll see the measurements of it now, pick one of the measurements and tell me what to change it to - http://www.morrismini.com/images/plasterminis/moke%20dimensioned.pdf
have a look at this too: http://www.morrismini.com/images/plasterminis/moke.pdf
if it says "ENABLE 3D CONTENT" in the middle of your screen, right-click at the edge of the screen (in the grey bit), go to "page display preferences", then "3D & multimedia" and check the box saying "enable 3d content" if it still doesn't work, or you don't have the option, bad luck
here's a bit more of the story behind them - viewtopic.php?t=77655
Author:  LeylandMiniPhil98 [ Tue Dec 03, 2013 10:08 pm ]
Ill have to have a look when i am back on a laptop.
Author:  womble99 [ Mon Dec 16, 2013 9:09 pm ]
So are we going to see a run of scalextric mokes? If so when do we get to place orders :)
Author:  simon k [ Tue Dec 17, 2013 8:23 pm ]
if someone will give me some dimensions.... I could do it myself but I only have a clubman like this to model it off http://www.ebay.co.uk/itm/251401588673
Author:  LeylandMiniPhil98 [ Tue Dec 17, 2013 11:06 pm ]
Ill try and get round to doing it today. If i remember correctly the mainstream scalextric cars are 1\32 scale. Ill have to find out if its true scale and then go from there. That said. Alot would go into making it a scalextric car. If im correct this would be made out of solid plastic so you need to do alot of drilling and carving to get the electronics set up in there. Also like my idea of a 1\24 kit, there would need to be extensive modifications to things like the steering column and underside to make it just like an off-the-shelf example.
