| ausmini https://ausmini.com/forums/ |
| Gearbox Casing Number Identification https://ausmini.com/forums/viewtopic.php?f=25&t=86659 |
| Author: | Mick [ Sat Jul 26, 2014 9:58 pm ] |
| Post subject: | Gearbox Casing Number Identification |
I'll pay my respects to The Mini Cooper Register, in particular Mini4Ever as this is where this list is sourced from. This is a list of Gearbox Identifications, as its a question that comes up on here from time to time. Mini Mk I 22A104: Cone synchro magic wand rubber joint 22A363: Cone synchro magic wand rubber joint 22G68: A type (22A381 laygear) or B type (22G231 laygear)magic wand rubber joint (*) (1) 22G382: B type (22G231 laygear) magic wand rubber joint (*) Cooper Mk I 22G68: A type (22G76 or 22G197 laygear for 997 and 22G204 laygear) or B type (22G232 laygear for 998) remote rubber joint (*) (2) Cooper S Mk I 22G190: A type (22G204 laygear) or B type (22G232 laygear) remote on 970/1071 rubber joint (*) (3) 22G333: B type (22G232 laygear) remote on 970/1275 rubber joint or Hardy Spicer(*) (4) Mini Mk II 22A1288: 3-synchro B-type (22G231 laygear) magic wand rubber joint 22G1128: 4-synchro (22G927 laygear) remote rubber joint (*) 22G846: 4-synchro, as for 22G1128 Mini K and 1098 Clubman Cooper Mk II 22A1228: 3-synchro B-type (22G232 laygear) remote rubber joint (see below, casing number should be 22A1288) 22G1128: 4-synchro (22G927 laygear) remote rubber joint Cooper S Mk II 22A1522: 3-synchro (22G232 laygear) remote Hardy Spicer (*) 22G1128: 4-synchro (22G1040 laygear) remote Hardy Spicer (*) Cooper S Mk III 22G1128: 4-synchro (22G1040 laygear) remote Hardy Spicer Remarks: 1) There exit casings with and without two round moldings on the fins at the front side and I was only able to confirm for B-type (22G231 laygear) 2) I was only able to confirm 22G232 laygear for 998 3) I was only able to confirm 22G232 laygear for 970 4) Difference between the engine sizes is that the 22G333 for 970 misses the notch cut out at the radiator - front corner. Hardy Spicer only on 1275 of postMay 66. 5) 22G232 laygear has been renumbered to 22G1100 |
| Author: | winabbey [ Sun Jul 27, 2014 1:14 pm ] |
| Post subject: | Re: Gearbox Casing Number Identification |
Thanks Mick. Which of those were used on Australian built cars? |
| Author: | Mick [ Sun Jul 27, 2014 1:29 pm ] |
I'm no gearbox aficionado,the only ones I have dealt with are the 22G68, (Early Cooper) 22G333, (Mk1 Cooper S) 22G1128, and (2 Mk2 Coopers and a couple of Mini K's) 22A1288. (A Deluxe I owned I think?) |
| Page 1 of 1 | All times are UTC + 10 hours |
| Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
