It is currently Tue Aug 19, 2025 10:30 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Sat Jul 26, 2014 9:58 pm
I'll pay my respects to The Mini Cooper Register, in particular Mini4Ever as this is where this list is sourced from.
This is a list of Gearbox Identifications, as its a question that comes up on here from time to time.
Mini Mk I
22A104: Cone synchro magic wand rubber joint
22A363: Cone synchro magic wand rubber joint
22G68: A type (22A381 laygear) or B type (22G231 laygear)magic wand rubber joint (*) (1)
22G382: B type (22G231 laygear) magic wand rubber joint (*)
Cooper Mk I
22G68: A type (22G76 or 22G197 laygear for 997 and 22G204 laygear) or B type (22G232 laygear for 998) remote rubber joint (*) (2)
Cooper S Mk I
22G190: A type (22G204 laygear) or B type (22G232 laygear) remote on 970/1071 rubber joint (*) (3)
22G333: B type (22G232 laygear) remote on 970/1275 rubber joint or Hardy Spicer(*) (4)
Mini Mk II
22A1288: 3-synchro B-type (22G231 laygear) magic wand rubber joint
22G1128: 4-synchro (22G927 laygear) remote rubber joint (*)
22G846: 4-synchro, as for 22G1128 Mini K and 1098 Clubman
Cooper Mk II
22A1228: 3-synchro B-type (22G232 laygear) remote rubber joint (see below, casing number should be 22A1288)
Cooper S Mk II
22A1522: 3-synchro (22G232 laygear) remote Hardy Spicer (*)
22G1128: 4-synchro (22G1040 laygear) remote Hardy Spicer (*)
Cooper S Mk III
Remarks:
1) There exit casings with and without two round moldings on the fins at the front side and I was only able to confirm for B-type (22G231 laygear)
2) I was only able to confirm 22G232 laygear for 998
3) I was only able to confirm 22G232 laygear for 970
4) Difference between the engine sizes is that the 22G333 for 970 misses the notch cut out at the radiator - front corner. Hardy Spicer only on 1275 of postMay 66.
5) 22G232 laygear has been renumbered to 22G1100
PostPosted: Sun Jul 27, 2014 1:14 pm
Thanks Mick.
Which of those were used on Australian built cars?
PostPosted: Sun Jul 27, 2014 1:29 pm
I'm no gearbox aficionado,the only ones I have dealt with are the
22G68, (Early Cooper)
22G333, (Mk1 Cooper S)
22G1128, and (2 Mk2 Coopers and a couple of Mini K's)
22A1288. (A Deluxe I owned I think?)
Users browsing this forum: No registered users and 204 guests
