It is currently Sat Aug 16, 2025 6:15 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Sun Feb 02, 2014 4:01 pm
This is collated from someone else's hard work from some time ago, I have no idea who it was.
Please, if it is yours, or you know who, let me know!
But it could be useful from time to time so I will add it here.
List of Engine Bolts
Timing Cover
• 5 x Bolts Cap Head 5/16”UNF (3/4” Long)
• 6 x Bolts Cap Head 1/4”UNF (7/16” Long)
• 5 x Washers 5/16”PLN (5/8” OD)
• 5 x Washers 5/16”SPR (1/2” OD)
• 6 x Washers 1/4”PLN (9/16” OD)
• 6 x Washers 1/4”SPR (7/16” OD)
• 1 x Nut 5/16”UNF (1/2” Head)
• 1 x Nut 1/4”UNF (7/16” Head)
Coolant Circuit
• 2 x Bolts Heater Tap 1/4” UNF (7/16” Head, 1/2” Long)
• 2 x Washers Heater Tap 1/4” SPR (3/8” OD)
• 2 x Bolts Radiator Top 1/4” UNF (7/16” Head, 1 1/2” Long)
• 2 x Washers Radiator Top 1/4”PLN (9/16” OD)
• 2 x Bolts (Water Pump) 5/16”UNF (1/2” Head, 2” Long)
• 2 x Bolts (Water Pump) 5/16”UNF (1/2” Head, 1” Long)
• 4 x Washers (Water Pump) 5/16”PLN (5/8” OD)
• 4 x Washers (Water Pump) 5/16”SPR (1/2” OD)
Thermostat (Short)
• 3 x Bolts 5/16 UNC (1/2” Head, 1 1/2” Long)
• 3 x Washers 5/16” SPR (1/2” OD)
Engine Electrical
• 2 x Bolts (Alt’ top) 5/16”UNF (1/2” Head, 2” Long)
• 1 x Bolt (Alt’ Bottom) M8x20
• 1 x Nut (Alt’ Bottom) M8 NyLoc
• 4 x Washers (Alternator) 5/16”PLN (5/8” OD)
• 4 x Washers (Alternator) 5/16”SPR (1/2” OD)
• 2 x Nuts (Alternator) 5/16”UNF (1/2” Head)
• 2 x Bolts Starter Motor 3/8”UNC (9/16” Head, 1 1/4” Long)
• 2 x Washers Starter motor 3/8”SPR (5/16” OD)
• 1 x Bolt (A+ Distributor) 5/16” UNF (1/2” Head, 3/4” Long)
Clutch Slave (Non verto)
• 2 x Bolts (Cyl Mount) 3/8”UNC (9/16” Head, 1” Long)
• 2 x Washers (Cyl Mount) 3/8”SPR (5/8” OD)
• 1 x Bolt (Arm Stop) 1/4”UNF (7/16” Head, 1” Long)
• 1 x Lock Nut (Arm Stop) 1/4”UNF (7/16” Head)
Clutch Cover
• 8 x Bolts 5/16”UNC (1/2” Head, 1” Long)
• 8 x Washers 5/16”SPR (1/2” OD)
• 8 x Washers 5/16”PLN (5/8” OD)
Tappet Chest
• 2 x Bolts 5/16” UNF (1/2” Head, 1 1/4” long)
• 2 x Washers 5/16 PLN (5/8” OD)
Pre A+ Distributor Drive
• 1x Bolt 1/4”UNF (7/16” Head, 3/4” long)
• 1x Washer 1/4”SPR (3/8” OD)
Fuel Pump
• 2 x Bolt 5/16” UNC (1/2 Head , 1 1/2”long)
• 2 x Washers 5/16” SPR (1/2” OD)
• 2 x Washers 5/16” PLN (5/8” OD)
Oil Filter Housing
• 2 x Bolt 3/8” UNC (9/16” Head, 1” Long)
• 2 x Washers 3/8” SPR
• 2 x Washers 3/8”PLN (15/16” OD)
Manifold Bolts
• 6 x Bolt 5/16 UNF (1” Long)
• 6 x Washers 5/16” SPR (1/2” OD)
• 6 x Washers 5/16” PLN (5/8” OD)
Users browsing this forum: No registered users and 69 guests
