Mini Dimensions and Weights https://ausmini.com/forums/viewtopic.php?f=25&t=82046 |
Author: | Panthersteve [ Wed Jul 10, 2013 8:38 am ] |
Post subject: | Mini Dimensions and Weights |
Hi This is what I was thinking, let me know if this is ok or not in the mini dimensions thread viewtopic.php?t=82040 . Cheers Steve Please let me know if there are errors that need changing or you have additional material for this thread. The links are http://www.minimania.com/article/596/Mi ... Dimensions http://www.theminiforum.co.uk/forums/in ... omsearch=1 or alternatively find it all below. ![]() COMPONENT WEIGHTS Please bear in mind that the following is based on UK machines so may not be exact. BODY Bodyshell (Bare): 140.6 kg Bonnet Hook Safety Catch: 0.051 kg Bonnet Hinge (Mk3 including bolt, nuts x 3 & washers x 6) 0.132 kg Bonnet Locking Pin & Spring: 0.075 kg Bonnet Mk2: 7.7 kg Bonnet Mk3 (Stripped): 5.900 kg Bonnet Prop & Fixings Mk3: 0.145 kg Bonnet Release Lever Mechanism Assembly: 0.293 kg Boot Badge (Mini 1000) Mk3: 0.052 kg Boot Handle & Catch Assembly Mk3: 0.272 kg Boot Hinge & Fixings each: 0.185 kg Boot Lid Cables & Fixings each side: 0.022 kg Boot Lid Mk3 (Stripped): 4.305 kg Boot Lid Mk3 (Complete with all parts including hinges): 5.582 kg Boot Number Plate Light Unit & Fixings Mk3: 0.495 kg Boot Rubber Seal (Fitted to boot) Mk3: 0.254 kg Boot Rubber Seal Clips x 26 Mk3: 0.019 kg Boot Rubber Seal (Fitted to body): 0.410 kg Bumpers (BMC Cooper S) each: 2.150 kg Bumpers (Chrome) each: 1.650 kg Bumper Front (1275 GT): 2.450 kg Bumper Rear (1275 GT): 1.990 kg Bumper Over Rider each: 0.260 kg Companion Bin Cards pair: 0.390 kg "C" Pillar Cards pair: 0.209 kg Dash Ashtray Mk3: 0.063 kg Dash Bottom Rail Cover Mk3: 0.413 kg Dash Card: 0.540 kg Dash Centre Binnacle (Including Speedo, Water & Oil Gauges): 1.262 kg Door Catch/Lock Assembly Mk3 (On Door): 0.321 kg Door Catch/Jam & Striker Plate Mk3 (On Body Pillar): ? kg Door Handle Mk3 (including lever): 0.355 Door Hinge Support Plate Stainless (each): Door Hinge Nuts & Washers Stainless (per hinge): Door Hinge Lower Mk3: 0.283 kg Door Hinge Upper Mk3: 0.296 kg Door Lock Lever Assembly Mk3: 0.064 kg Door Mk 1 & 2 Complete (Not including hinges): 15.0 kg Door Mk3 with side impact bar. Complete with hinges (Not including mirror): 18,6 kg Door Card Mk3 on (each): 1.128 kg 1/4 Panel Card each: 0.784 kg Door Catch Assembly (Body Pillar) each side: 0.193 kg Door Check Mk3 each: 0.067 kg Door Check Seal Mk3 each: 0.031 kg Door Exterior Handle & Fixings Mk3 each: 0.363 kg Door Glass & Channel Mk3 each side: 4.365 kg Door Glass Front Section Mk1 & 2 (per door): 1.913 kg Door Glass Front Section Catch Mk1 & 2 (per door): 0.030 kg Door Glass Rear Section Mk1 & 2 (per door): 1.402 kg Door Glass Rear Section Catch Mk1 & 2 (per door): 0.027 kg Door Interior Handle & Fixings Mk3 each: 0.042 kg Door Locking Lever Mechanism Mk3 each: 0.066 kg Door Opening Lever & Fixings Mk3 each: 0.038 kg Door Release Rod Mechanism each: 0.203 kg Door Surround Rubber Seal (each): 0.880 kg Door Skin Steel (Mk3): 4.079 kg Door Window Winder Handle Mk3 each: 0.035 kg Firewall Hole Cover Rear Mk3: 0.163 kg Flitch Panel Air Vent Blanking Cover each: 0.052 kg Front End Carbon Fibre One Piece (Carbon Weezel Product) 1.6 – 2.2 kg Depending on spec Front End Carbon Fibre Two Piece (Carbon Weezel Product) 2.0 – 2.8 kg Depending on spec Front End Steel Non Genuine Panels (not including bonnet): 9.0 kg Approx Front Grille Bonnet Trim Mk2 & 3: 0.115 kg Front Grille Side Trim Mk2 & 3 (each side): 0.051 kg Front Grille 8 Slat Mk3: 1.176 kg Front Panel: 4.185 kg Front Seat (BMC Cooper S) each: 7.270 kg Front Seat (1275 GT) each: 7.260 kg Front Wing (early): 2.340 kg Headlamp Bowl Kit Metal Complete (per side): 0.568 kg Headlamp Bowl Kit Plastic Complete (per side): 0.250 kg Headlamp Sealed Beam Unit (each): 0.540 kg Interior Mirror Mk3 & Fixings: 0.113 kg Number Plate (Plastic) each: 0.231 kg Number Plate (Pressed Alloy) each: 0.187 kg Parcel Shelf Card: 0.721 kg Rear Wheel Arch Trim pair: 0.056 kg Rear Companion Bin (each): 0.900 kg approx Rear Companion Bin Trim (each): 0.100 kg approx Rear Light Unit Mk2/3 & Rubber Gasket each side: 0.651 kg Rear Quarter Window (Opening) Mk1 & 2 each: 3.218 kg Rear Quarter Window (Opening) Mk3 each: 3.373 kg Rear Seat Squab (Mk3 Cloth with Vinyl edges): 2.298 kg Rear Seat Cushion (Mk3 Cloth with Vinyl edges): 2.225 kg Seam Finisher Front (each): 0.110 kg Seam Finisher Rear (each): 0.128 kg Seam Finisher Clips (x 30): 0.022 kg Subframe Front Dry (early twin bolt): 16.7 kg Subframe Tower Spacer Plate (each): 0.138 kg Subframe Top Mount Tab Plates Twin Bolt Including Rubber Grommet (each): 0.030 kg Subframe Top Mount Bolt Twin Bolt (each): 0.062 kg Subframe (Rear): 14.2 kg Subframe (Rear) Front Mounting Pin & Nut (per side): 0.197 kg Subframe (Rear) Trunnion early (each): 0.181 kg Window (Rear Mk2 on): 4.090 kg Window Rear Rubber Seal (Mk3 on): 1.054 kg Windscreen Front (Laminated): 5.700 kg Windscreen Front Rubber Seal (without insert): 1.152 kg Windscreen Front Rubber Seal Insert: 0.217 kg Window Winder Mechanism each: 1.510 kg ENGINE Alternator: 4.335 kg Alternator Adjustment Bracket: 0.051 kg Alternator Adjustment Bracket Bolt, Nut & Washers: 0.033 kg Alternator to Adjustment Bracket Bolt & Washer: 0.014 kg Alternator Mounting Bracket to Block A+: 0.075 kg Alternator Mounting Bracket Bolts Flanged x 2: 0.024 kg Alternator Mounting Bolts, Nuts & Washers x 2: 0.054 kg Big End Connecting Rod Bearing Set: 0.182 kg Camshaft SW05-07: 1.850 kg Camshaft Woodruff Key: 0.002 kg Camshaft Followers x 8: 0.369 kg Camshaft Thrust Plate: 0.033 kg Cam Thrust Plate 1/4" UNF Bolts & Star Washers x 3: 0.021 kg Camshaft Duplex Vernier Sprocket: 0.725 kg Camshaft Key Washer: 0.043 kg Camshaft Lock Tab Washer: 0.014 kg Camshaft Retaining Nut: 0.027 kg Carburettor HIF-38: 1.388 kg Cooling Fan Plastic 11 Blade: 0.165 kg Connecting Rods x 4: 2.600 kg approx Connecting Rod (BMC 1275 Cooper S) each: 0.680 kg Core Plugs x 5: 0.080 kg Countersink Screws on Timing Plate for Duplex Gears: 0.008 kg Crankshaft (BMC 1275 Cooper S): 11.430 kg Crankshaft Duplex Sprocket: 0.323 kg Crankshaft Oil Thrower: 0.026 kg Crankshaft Main Bearings Set: 0.170 kg Crankshaft Pulley Bolt: 0.144 kg Crankshaft Pulley Locking Tab Washer: 0.014 kg Crankshaft Pulley TAM2011: 1.290 kg Crankshaft Sprocket Packing Washer: 0.000.5 kg Crankshaft Thrust Washer Set: 0.076 kg Crankshaft Woodruff Key: 0.004 kg Cylinder Head 12G940B Valves Fitted: 13.852 kg approx Cylinder Head 12G940 MG Valves Fitted: 12.50 kg approx Cylinder Head Gasket: 0.092 kg Cylinder Head Studs & Nuts Short x 5: 0.320 kg Cylinder Head Studs & Nuts Long x 4: 0.344 kg Distributor 65DM4 Electronic: 0.796 kg Distributor Clamp: 0.081 kg Distributor Clamp Bolt & Washer: 0.026 kg Distributor Drive Spindle A+: 0.194 kg Dipstick A+ Stainless Steel: 0.90 kg Dynamo Rear Mounting Bracket: 0.101 kg Duplex Timing Chain: 0.081 kg Engine Earth Strap: 0.059 kg Engine Mount (each): 0.250 kg Engine Mount to Clutch Cover Bolts & Washers: 0.039 kg Engine Mount to Radiator Bracket Bolts & Washers: 0.036 kg Engine Mount to Subframe Nuts, Bolts & Washers (per mount): 0.036 kg Engine Steady Bar Adjustable (Including Poly Bushes): 0.311 kg Engine to Gearbox Bolts, Washers, Studs & Nuts: 0.130 kg Exhaust Centre Pipe Section RC40 (Twin Box): 1.237 kg Exhaust Fitting Kit RC40: 0.820 kg Exhaust Manifold LCB (Fletcher): 2.705 kg Exhaust Manifold LCB “Y” Piece Including Brackets (Fletcher): 0.940 kg Exhaust Twin Box Section RC40 (Side Entry): 5.557 kg Exhaust Valve 29,2mm each: 0.046 kg Fuel, Water, Oil Pump & Oil Filter Housing Gaskets: 0.004 kg Fuel Pump Blanking Plate: 0.055 kg Fuel Pump Blanking Plate Bolts & Washers x 2: 0.026 kg HT Leads set of 5 x 8mm Silicone: 0.250 kg Inlet Manifold CAM6618 (Worked): 0.744 kg Inlet Valve 33.33mm each: 0.050 kg Manifold Gasket: 0.041 kg Oil Filler Cap (Black): 0.034 kg Oil Filler Cap (Red): 0.043 kg Oil Filter Housing & Oil Feed Pipe: 0.315 kg Oil Filter Housing Studs, Nuts & Washers x 2: 0.060 kg approx Oil Feed Pipe Banjo Bolt & Washers: 0.064 kg Oil Filter Spin On: 0.309 kg Oil Pressure Light Switch: 0.025 kg Oil Pressure Relief Assembly: 0.070 kg Oil Pressure T Piece with Adaptor Fitting: 0.071 Oil Pump: 0.493 kg Oil Pump Bolts Flanged x 2: 0.025 kg Piston with Rings & Pin (BMC 1275 Cooper S) each: 0.354 kg Primary Gear with Bush: 0.570 kg Primary Gear "C" Washer Assembly: 0.038 kg Primary Gear Thrust Washer: 0.018 kg Push Rods x 8 (1275): 0.421 kg Rocker Cover Alloy CAM6822: 0.748 kg Rocker Cover Brackets for splash guard: 0.061 kg Rocker Cover Steel: 0.586 kg Rocker Cover Gasket: 0.025 kg Rocker Post Stud & Nut Short x 2: 0.059 kg Rocker Post Stud & Nut Long x 2: 0.067 kg Rocker Shaft Assembly: 1.489 kg Rocker Stud Tab: 0.004 kg Rotor Arm for 65DM4: 0.016 kg Short Engine 1275 A+ Including the following parts fitted: Pistons – Con Rods – Crankshaft – Camshaft – Cam Followers – Oil Pump – Oil Pressure Relief Valve Assembly: 53.4 kg Standard Flywheel 7.58 kg Spark Plugs x 4: 0.800 kg Starter Motor Inertia 4.4 kg Starter Motor Pre-engaged 4.5 kg Thermostat: 0.057 kg Timing Chain Back Plate (Alloy): 0.388 kg Timing Chain Cover A+ with Breather: 0.621 kg Timing Cover 1/4" Bolts, Plain & Locking Washers x 6: 0.042 kg Timing Cover Crankshaft Oil Seal: 0.023 kg Timing Plate: 1.000 kg Timing Plate 5/16" Bolts & Washers x 6: 0.076 kg Timing Plate & Cover Gaskets: 0.014 kg Valve Spring (Single) each: 0.040 kg Valve Spring Cap each: 0.015 kg Valve Stem Collets x 8 Pairs: 0.016 kg Valve Stem Seals x 4: 0.006 kg Water Pump Bolts Flanged x 4: 0.079 kg Water Pump Pulley 3.7/8": 0.231 kg Water Pump Pulley 4.11/16": 0.290 kg Water Pump (without bypass): 0.865 kg Water Temperature Sender Switch: 0.030 kg TRANSMISSION Clutch Case Cover with Verto Lever: 2.100 kg Clutch Friction Plate Verto: 0.825 kg Clutch Lever Return Spring: 0.010 kg Clutch Master Cylinder: 0.680 kg Clutch Master Cylinder Clevis Pin & Split Pin: 0.008 kg Clutch Pressure Back Plate Standard Lightened (Pre Verto): 1.978 kg Clutch Pressure Back Plate Standard (Pre Verto): 2.600 kg* Clutch Pressure Plate Assembly (Verto): 4.2 kg Clutch Slave Cylinder (Pre-Verto): 0.540 kg Clutch Shouldered Bolts Competition Long x 3: 0.064 kg Clutch Shouldered Bolts Competition Short x 3 0.053 kg Clutch Spring Anchor Tab: 0.005 kg CV Joint Outer (each): 1.700 kg Drive Flange Alloy each: 0.57 kg Drive Flange each: 1.47 kg Drive Shaft Nearside Short: 1.286 kg Drive Shaft Offside Long: 1.575 kg Flywheel (BMC 1275 Cooper S): 7.360 kg Flywheel complete with Clutch (BMC 1275 Cooper S): 11.890 kg Flywheel Housing (A+): 3.231 kg Flywheel Standard Pre Verto: 7.580 kg Flywheel Lightened Standard Pre Verto: 6.050 kg Flywheel Bolt: 0.105 kg Gearbox (Including all gears & differential): 26 kg approx Gear Lever Rod Change without Gearknob: 0.651 kg Gear Lever Kad Quickshift without Gearknob: 0.732 kg Gear Lever Rubber Gaiter (remote change): 0.173 kg Hub Front (with bearings fitted): 1.337 kg Hub to Brake Disc Bolts x 4 (per side): 0.064 kg Hub Wheel Stud Standard (each): 0.019 kg Remote Gearchange Rear Support Bracket (Including Nuts, Bolts & Washers: 0.306 kg Rod Gearchange Linkage (Including Support Bracket): 2.095 kg Rod Gearchange Linkage Roll Pin: 0.003 kg SUSPENSION Bumpstop early two stud including Nuts & Washers (per side): 0.089 kg Front Suspension Alloy Cone Strut Including Knuckle Joint (each): 0.295 kg Front Suspension Bottom Arm (each): 0.840 kg Front Suspension Bottom Arm Bushes (per side): 0.037 kg Front Suspension Bottom Arm Pin including Nut & Washer (per side): 0.219 kg Front Upper Arm Complete Assembly Knuckle Joint, Nuts, Bolts & Washers (each): 2.392 kg Genuine Rubber Suspension Cone (each): 0.904 kg Knuckle Joint (each): 0.136 kg Radius Arm including Pin, Bush & Bearing (each): 5.089 kg Radius Arm Fully Built Including Non Spacered Drum (each): 11.120 kg Radius Arm Fully Built Including Spacered Drum (each): 12.500 kg Rear Hub Alloy (Mini Sport) each: 0.419 kg Rear Hub Nut (per side): 0.028 kg Rear Hub Standard (not including bearings) each: 0.931 kg Rear Hub Standard Including Bearings, Nut, Split Pin, & Cap: 1.445 kg Rear Subframe Poly Bushes x 4 (per side): 0.042 kg Rear Suspension Alloy Cone Strut Including Knuckle Joint (each): 0.670 kg Rebound Buffer (per side): 0.023 kg Shock Absorbers Front Gaz Adjustable (each): 1.416 kg Shock Absorbers Front Standard (each): 0.818 kg Shock Absorbers Rear Gaz Adjustable (each): 1.520 kg Shock Absorbers Rear Standard (each): 0.650 kg Shock Absorber to Radius Arm Nut & Washers (per side): 0.017 kg Shock Absorber Top Mount (per side): 0.409 kg Tie Bar Rod Heavy Duty Adjustable (each): 0.845 kg Tie Bar Rod Standard (each): 0.498 kg Tie Bar Rod to Bottom Arm Nut & Bolt (per side): 0.024 kg Tie Bar Rod Front Nut & Washer (per side): 0.045 kg STEERING Steering Rack Retaining "U" Bolts & Nuts (pair): 0.139 kg Steering Rack to Body Seal: 0.001 kg Steering Column complete with Steering Wheel Nut & Steering Lock: 2.573 kg Steering Column Pinch Bolt, Nut & Spring Washer: 0.015 kg Steering Column Bracket (Painted): 0.090 kg Steering Column Bracket (Chrome): 0.096 kg Steering Column Bracket Shear Bolts & Washers (pair): 0.037 kg Steering Column Bracket Shear Bolt Threaded Back Plate: 0.040 kg Steering Column to Bracket Nut, Bolt & Washer: 0.034 kg Steering Column Cowling (Mk3): 0.172 kg Steering Rack: 3.608 kg Steering Rack Track Rod End Locking Nut (each): 0.012 kg Steering Wheel Retaining Nut (early): 0.044 kg Track Rod End Long (each): 0.312 kg Track Rod End Standard (each): Swivel Hub Alloy (Mini Sport) each: 0.71 kg Swivel Hub Standard with Bearings, Steering Arm & Joints (per side): 3.055kg Swivel Hub Standard each: 1.73 kg BRAKES Brake Caliper Pad Split Pins x 2 (per side): 0.012 kg Brake Drum Rear Alloy Finned Built In Spacer (each): 1.750 kg Brake Drum Rear Non Spacered (each): 2.288 kg Brake Drum Rear Built In Spacer (each): 3.620 kg Brake Drum Retaining Screws Long x 2 (per side): 0.016 kg Brake Drum Retaining Screws Short x 2 (per side): 0.006 kg Brake Light Pressure Switch & 2 Way Union Assembly: 0.132 kg Brake Pads 8.4" (per side): 0.302 kg Brake Pad Clip 8.4" (per side): 0.006 kg Brake Rear Adjuster & Tappets: (per side): 0.073 Brake Regulator Valve (Early): 0.356 kg Brake Shoes Rear (both sides): 0.891 kg Brake Shoe Rear Return Springs (per side): 0.048 kg Brake Union 3 Way: 0.054 kg Caliper Alloy Four Pot: 1.15 kg Caliper Metro Four Pot: 3.48 kg Caliper Two Pot 7.5": 2.66 kg Caliper Two Pot 8.4": 3.479 kg Caliper 8.4" Mounting Bolts & Washers (per side): 0.053 kg Disc 8.4": 2.906 kg Disc 8.4” Back Plate (each): 0.365 kg Discs Vented 7.9 pair: 6.5 kg Discs Vented 8.4 pair: 6.9 kg Discs Rear KAD pair: 2.8 kg Handbrake Cable Back Plate Bracket (per side): 0.074 kg Handbrake Cable Drum Lever: 0.107 kg Handbrake Fairlead Pad (each): 0.009 kg Handbrake Fairlead Plate (each): 0.009 kg Handbrake Lever (early two cable) including mounting nuts, bolts & washers: 0.780 kg Handbrake Lever (later single cable) including mounting nuts, bolts & washers: 0.510 kg Handbrake Lever Grip (late): 0.071 kg Handbrake Quadrant Alloy (per side): 0.030 kg Handbrake Quadrant (per side): 0.112 kg Handbrake Quadrant Bolt, Nut & Washer (per side): 0.050 kg Hub & Disc 8.4" Assembly: 4.389 kg Master Cylinder Single (early): 0.610 kg Master Cylinder Clevis Pin & Split Pin: 0.008 kg Rear Brake Back Plate: 0.826 kg Rear Brake Back Plate Bolt, Nut & Washer x 3 (per side): 0.066 kg Rear Brake Cylinder: 0.351 kg Rear Brake Cylinder "C" Clip & Gasket (per cylinder): 0.003 kg Rear Brake Shoes Pair (per side): 0.464 kg Rear Hub Alloy (Mini Sport) each: 0.419 kg Rear Hub Standard (not including bearings) each: 0.931 kg Rear Hub Standard Including Bearings, Nut, Split Pin, & Cap: 1.445 kg MISCELLANEOUS Fluids Coolant Capacity: 3.5 litres = 3.5 kg Water: 1 Pint approx 0.575 kg Unleaded Petrol 1 Gallon (4.54 Litres) at 69 deg F (20 deg C): 3.324 kg Fuel System Fuel Tank 5.5 Gallon (25.0034 Litres): 4.437 kg Fuel Tank Retaining Strap 5.5 Gallon: 0.318 kg Locking Petrol Cap: 0.137 kg Engine Bay Bonnet Buffers Clubman pair: 0.015 kg Horn Mk3 Factory Fitted: 0.775 kg Master Cylinder Mounting Plate: 0.110 kg Voltage Regulator Control Box: 0.427 kg Windscreen Washer Bottle Including Electric Pump: 0.275 kg Windscreen Washer Pipe Assembly Including "T" Piece (bulkhead mounted): 0.026 kg Wiper Hole Blanks Stainless (pair): 0.041 Wiper Mechanism (Mk3): 0.579 kg Wiper Motor 2 Speed (Mk3): 1.628 kg Wiper Motor to Body Rubber Pad: 0.026 kg Wiper Mounting Bracket Including Rubber: 0.098 kg Interior Accelerator Pedal (without rubber): 0.272 kg Dash Ashtray: 0.061 kg Door Release Rod Mechanism (each): 0.203 kg Interior Mirror including fixing Screws (late black plastic): 0.143 kg Pedal Box: 2.100 kg Roll Cage Safety Devices Six Point Bolt In (Including Fixings): Roll Cage Rear Section with Diagonal: 15 kg Roll Cage Front Section: 10 kg Roll Cage Dash Bar: 3 kg Roll Cage Door Bar (Each): 2.5 kg Seat Cobra Classic (not including Subframe) 6.1 kg Seat Mamba Classic (not including Subframe) 6.7 kg Seat Cross Member Front Mount (Mk3 bolt-on) Each: 0.144 kg Seat Catch Floor Brackets (each): 0.272 kg Sound Deadening (floor & rear quarter panels): 9.0 kg approx Window Winder Sealant/Goo: 0.084 kg Wheels & Outer Trim Door Handle Chrome Mk3 (each): 0.371 kg Front Indicator Lense Glass (each): 0.080 kg Front Indicator Lense Plastic (each): 0.015 kg Front Indicator Unit with Plastic Lense (each): 0.086 kg Grille Quick Release Buttons/Fittings: 0.091 kg Headlamp Ring Trim (each): 0.149 kg Sill Seam Rubber Trim both sides: 0.370 kg Washer Jets Chrome Twin Type (each): 0.019 kg Wiper Arm Complete including Blade (each): 0.110 kg Wiper Hole Blanks Stainless (pair): 0.041 Wiper Wheelbox Bezels Chrome Including Nuts & Seals (pair): 0.048 kg Wheel 1275 GT Steel 10” x 4.5” (without tyre): 4.090 kg* Wheel Cooper S Steel 10" x 3.5" (without tyre): 3.520 kg* Wheel Cooper S Steel 10" x 4.5" with 165/70 x10" Tyre: 9.000 kg* Wheel Cooper 12" x 4.5" with 145/60 x12" Tyre: 9.200 kg* Wheel Nut (chrome): 0.035 kg Wheel Minilite Alloy 10" x 5" (wheel only): 3.770 kg Wheel Minilite Alloy 12" x 5" (wheel only): 4.570 kg Wheel Minilite Alloy 13" x 6" (wheel only): 6.510 kg Wheel Minilite Magnesium 10" x 6" (wheel only): 2.925 kg* Wheel Sports Pack Alloy 13" x 6" (wheel only): 6.760 kg Wheel Stud (each): 0.022 kg Wheel Stud 55mm for rear brake drum with built-in spacer (each): 0.034 kg Wheel Super Light Alloy 13" x 6" (wheel only): 5.620 kg Wheel Super Light Alloy 13" x 7" with 175/50 x13" Tyre: 12.100 kg* Fresh Air Ducts & Heating Air Intake Inner Wing Duct (Mk3): 0.170 kg Air Intake Hose to Distribution Box (Mk3): 0.180 kg Demister Duct Left Hand Including Screws (Mk3): 0.046 kg Demister Duct Right Hand Including Screws (Mk3): 0.057 kg Distribution Box Including Nuts, Washers & Seal (early Mk3 without face vents): 0.249 kg Heater Box Metal Case (Mk3): 4.4 kg Heater Matrix (Metal): 1.226 kg Hose Inner Wing to Heater (Mk3): 0.081 kg Hose Heater to Demister Left Hand Duct (Mk3): 0.037 kg Hose Heater to Demister Right Hand Duct (Mk3): 0.037 kg Electric Fuse Box 1976-96 (Including the 4 fuses plus 2 spares): 0.081 kg Headlamp Bowl Inner & Rim Lamp Holder (each): 0.221 kg Headlamp Bowl Metal (each): 0.270 kg Indicator Switch Assembly Single Stalk (Mk3): 0.199 kg Rear Light Unit Mk2 (Including Rubber Gasket): 0.649 kg Wiper Mechanism (Mk3): 0.579 kg Wiper Motor 2 Speed (Mk3): 1.628 kg Wiring Loom Front Early Mk3: 1.511 kg Wiring Loom Rear Early Mk3: Wiring Loom Head Early Mk3 (per side): 0.075 kg |
