It is currently Sat Aug 16, 2025 9:29 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Wed Jul 10, 2013 8:38 am
Hi
This is what I was thinking, let me know if this is ok or not in the mini dimensions thread viewtopic.php?t=82040 .
Steve
Please let me know if there are errors that need changing or you have additional material for this thread.
The links are
http://www.minimania.com/article/596/Mi ... Dimensions
http://www.theminiforum.co.uk/forums/in ... omsearch=1
or alternatively find it all below.
COMPONENT WEIGHTS
Please bear in mind that the following is based on UK machines so may not be exact.
BODY
Bodyshell (Bare): 140.6 kg
Bonnet Hook Safety Catch: 0.051 kg
Bonnet Hinge (Mk3 including bolt, nuts x 3 & washers x 6) 0.132 kg
Bonnet Locking Pin & Spring: 0.075 kg
Bonnet Mk2: 7.7 kg
Bonnet Mk3 (Stripped): 5.900 kg
Bonnet Prop & Fixings Mk3: 0.145 kg
Bonnet Release Lever Mechanism Assembly: 0.293 kg
Boot Badge (Mini 1000) Mk3: 0.052 kg
Boot Handle & Catch Assembly Mk3: 0.272 kg
Boot Hinge & Fixings each: 0.185 kg
Boot Lid Cables & Fixings each side: 0.022 kg
Boot Lid Mk3 (Stripped): 4.305 kg
Boot Lid Mk3 (Complete with all parts including hinges): 5.582 kg
Boot Number Plate Light Unit & Fixings Mk3: 0.495 kg
Boot Rubber Seal (Fitted to boot) Mk3: 0.254 kg
Boot Rubber Seal Clips x 26 Mk3: 0.019 kg
Boot Rubber Seal (Fitted to body): 0.410 kg
Bumpers (BMC Cooper S) each: 2.150 kg
Bumpers (Chrome) each: 1.650 kg
Bumper Front (1275 GT): 2.450 kg
Bumper Rear (1275 GT): 1.990 kg
Bumper Over Rider each: 0.260 kg
Companion Bin Cards pair: 0.390 kg
"C" Pillar Cards pair: 0.209 kg
Dash Ashtray Mk3: 0.063 kg
Dash Bottom Rail Cover Mk3: 0.413 kg
Dash Card: 0.540 kg
Dash Centre Binnacle (Including Speedo, Water & Oil Gauges): 1.262 kg
Door Catch/Lock Assembly Mk3 (On Door): 0.321 kg
Door Catch/Jam & Striker Plate Mk3 (On Body Pillar): ? kg
Door Handle Mk3 (including lever): 0.355
Door Hinge Support Plate Stainless (each):
Door Hinge Nuts & Washers Stainless (per hinge):
Door Hinge Lower Mk3: 0.283 kg
Door Hinge Upper Mk3: 0.296 kg
Door Lock Lever Assembly Mk3: 0.064 kg
Door Mk 1 & 2 Complete (Not including hinges): 15.0 kg
Door Mk3 with side impact bar. Complete with hinges (Not including mirror): 18,6 kg
Door Card Mk3 on (each): 1.128 kg
1/4 Panel Card each: 0.784 kg
Door Catch Assembly (Body Pillar) each side: 0.193 kg
Door Check Mk3 each: 0.067 kg
Door Check Seal Mk3 each: 0.031 kg
Door Exterior Handle & Fixings Mk3 each: 0.363 kg
Door Glass & Channel Mk3 each side: 4.365 kg
Door Glass Front Section Mk1 & 2 (per door): 1.913 kg
Door Glass Front Section Catch Mk1 & 2 (per door): 0.030 kg
Door Glass Rear Section Mk1 & 2 (per door): 1.402 kg
Door Glass Rear Section Catch Mk1 & 2 (per door): 0.027 kg
Door Interior Handle & Fixings Mk3 each: 0.042 kg
Door Locking Lever Mechanism Mk3 each: 0.066 kg
Door Opening Lever & Fixings Mk3 each: 0.038 kg
Door Release Rod Mechanism each: 0.203 kg
Door Surround Rubber Seal (each): 0.880 kg
Door Skin Steel (Mk3): 4.079 kg
Door Window Winder Handle Mk3 each: 0.035 kg
Firewall Hole Cover Rear Mk3: 0.163 kg
Flitch Panel Air Vent Blanking Cover each: 0.052 kg
Front End Carbon Fibre One Piece (Carbon Weezel Product) 1.6 – 2.2 kg Depending on spec
Front End Carbon Fibre Two Piece (Carbon Weezel Product) 2.0 – 2.8 kg Depending on spec
Front End Steel Non Genuine Panels (not including bonnet): 9.0 kg Approx
Front Grille Bonnet Trim Mk2 & 3: 0.115 kg
Front Grille Side Trim Mk2 & 3 (each side): 0.051 kg
Front Grille 8 Slat Mk3: 1.176 kg
Front Panel: 4.185 kg
Front Seat (BMC Cooper S) each: 7.270 kg
Front Seat (1275 GT) each: 7.260 kg
Front Wing (early): 2.340 kg
Headlamp Bowl Kit Metal Complete (per side): 0.568 kg
Headlamp Bowl Kit Plastic Complete (per side): 0.250 kg
Headlamp Sealed Beam Unit (each): 0.540 kg
Interior Mirror Mk3 & Fixings: 0.113 kg
Number Plate (Plastic) each: 0.231 kg
Number Plate (Pressed Alloy) each: 0.187 kg
Parcel Shelf Card: 0.721 kg
Rear Wheel Arch Trim pair: 0.056 kg
Rear Companion Bin (each): 0.900 kg approx
Rear Companion Bin Trim (each): 0.100 kg approx
Rear Light Unit Mk2/3 & Rubber Gasket each side: 0.651 kg
Rear Quarter Window (Opening) Mk1 & 2 each: 3.218 kg
Rear Quarter Window (Opening) Mk3 each: 3.373 kg
Rear Seat Squab (Mk3 Cloth with Vinyl edges): 2.298 kg
Rear Seat Cushion (Mk3 Cloth with Vinyl edges): 2.225 kg
Seam Finisher Front (each): 0.110 kg
Seam Finisher Rear (each): 0.128 kg
Seam Finisher Clips (x 30): 0.022 kg
Subframe Front Dry (early twin bolt): 16.7 kg
Subframe Tower Spacer Plate (each): 0.138 kg
Subframe Top Mount Tab Plates Twin Bolt Including Rubber Grommet (each): 0.030 kg
Subframe Top Mount Bolt Twin Bolt (each): 0.062 kg
Subframe (Rear): 14.2 kg
Subframe (Rear) Front Mounting Pin & Nut (per side): 0.197 kg
Subframe (Rear) Trunnion early (each): 0.181 kg
Window (Rear Mk2 on): 4.090 kg
Window Rear Rubber Seal (Mk3 on): 1.054 kg
Windscreen Front (Laminated): 5.700 kg
Windscreen Front Rubber Seal (without insert): 1.152 kg
Windscreen Front Rubber Seal Insert: 0.217 kg
Window Winder Mechanism each: 1.510 kg
ENGINE
Alternator: 4.335 kg
Alternator Adjustment Bracket: 0.051 kg
Alternator Adjustment Bracket Bolt, Nut & Washers: 0.033 kg
Alternator to Adjustment Bracket Bolt & Washer: 0.014 kg
Alternator Mounting Bracket to Block A+: 0.075 kg
Alternator Mounting Bracket Bolts Flanged x 2: 0.024 kg
Alternator Mounting Bolts, Nuts & Washers x 2: 0.054 kg
Big End Connecting Rod Bearing Set: 0.182 kg
Camshaft SW05-07: 1.850 kg
Camshaft Woodruff Key: 0.002 kg
Camshaft Followers x 8: 0.369 kg
Camshaft Thrust Plate: 0.033 kg
Cam Thrust Plate 1/4" UNF Bolts & Star Washers x 3: 0.021 kg
Camshaft Duplex Vernier Sprocket: 0.725 kg
Camshaft Key Washer: 0.043 kg
Camshaft Lock Tab Washer: 0.014 kg
Camshaft Retaining Nut: 0.027 kg
Carburettor HIF-38: 1.388 kg
Cooling Fan Plastic 11 Blade: 0.165 kg
Connecting Rods x 4: 2.600 kg approx
Connecting Rod (BMC 1275 Cooper S) each: 0.680 kg
Core Plugs x 5: 0.080 kg
Countersink Screws on Timing Plate for Duplex Gears: 0.008 kg
Crankshaft (BMC 1275 Cooper S): 11.430 kg
Crankshaft Duplex Sprocket: 0.323 kg
Crankshaft Oil Thrower: 0.026 kg
Crankshaft Main Bearings Set: 0.170 kg
Crankshaft Pulley Bolt: 0.144 kg
Crankshaft Pulley Locking Tab Washer: 0.014 kg
Crankshaft Pulley TAM2011: 1.290 kg
Crankshaft Sprocket Packing Washer: 0.000.5 kg
Crankshaft Thrust Washer Set: 0.076 kg
Crankshaft Woodruff Key: 0.004 kg
Cylinder Head 12G940B Valves Fitted: 13.852 kg approx
Cylinder Head 12G940 MG Valves Fitted: 12.50 kg approx
Cylinder Head Gasket: 0.092 kg
Cylinder Head Studs & Nuts Short x 5: 0.320 kg
Cylinder Head Studs & Nuts Long x 4: 0.344 kg
Distributor 65DM4 Electronic: 0.796 kg
Distributor Clamp: 0.081 kg
Distributor Clamp Bolt & Washer: 0.026 kg
Distributor Drive Spindle A+: 0.194 kg
Dipstick A+ Stainless Steel: 0.90 kg
Dynamo Rear Mounting Bracket: 0.101 kg
Duplex Timing Chain: 0.081 kg
Engine Earth Strap: 0.059 kg
Engine Mount (each): 0.250 kg
Engine Mount to Clutch Cover Bolts & Washers: 0.039 kg
Engine Mount to Radiator Bracket Bolts & Washers: 0.036 kg
Engine Mount to Subframe Nuts, Bolts & Washers (per mount): 0.036 kg
Engine Steady Bar Adjustable (Including Poly Bushes): 0.311 kg
Engine to Gearbox Bolts, Washers, Studs & Nuts: 0.130 kg
Exhaust Centre Pipe Section RC40 (Twin Box): 1.237 kg
Exhaust Fitting Kit RC40: 0.820 kg
Exhaust Manifold LCB (Fletcher): 2.705 kg
Exhaust Manifold LCB “Y” Piece Including Brackets (Fletcher): 0.940 kg
Exhaust Twin Box Section RC40 (Side Entry): 5.557 kg
Exhaust Valve 29,2mm each: 0.046 kg
Fuel, Water, Oil Pump & Oil Filter Housing Gaskets: 0.004 kg
Fuel Pump Blanking Plate: 0.055 kg
Fuel Pump Blanking Plate Bolts & Washers x 2: 0.026 kg
HT Leads set of 5 x 8mm Silicone: 0.250 kg
Inlet Manifold CAM6618 (Worked): 0.744 kg
Inlet Valve 33.33mm each: 0.050 kg
Manifold Gasket: 0.041 kg
Oil Filler Cap (Black): 0.034 kg
Oil Filler Cap (Red): 0.043 kg
Oil Filter Housing & Oil Feed Pipe: 0.315 kg
Oil Filter Housing Studs, Nuts & Washers x 2: 0.060 kg approx
Oil Feed Pipe Banjo Bolt & Washers: 0.064 kg
Oil Filter Spin On: 0.309 kg
Oil Pressure Light Switch: 0.025 kg
Oil Pressure Relief Assembly: 0.070 kg
Oil Pressure T Piece with Adaptor Fitting: 0.071
Oil Pump: 0.493 kg
Oil Pump Bolts Flanged x 2: 0.025 kg
Piston with Rings & Pin (BMC 1275 Cooper S) each: 0.354 kg
Primary Gear with Bush: 0.570 kg
Primary Gear "C" Washer Assembly: 0.038 kg
Primary Gear Thrust Washer: 0.018 kg
Push Rods x 8 (1275): 0.421 kg
Rocker Cover Alloy CAM6822: 0.748 kg
Rocker Cover Brackets for splash guard: 0.061 kg
Rocker Cover Steel: 0.586 kg
Rocker Cover Gasket: 0.025 kg
Rocker Post Stud & Nut Short x 2: 0.059 kg
Rocker Post Stud & Nut Long x 2: 0.067 kg
Rocker Shaft Assembly: 1.489 kg
Rocker Stud Tab: 0.004 kg
Rotor Arm for 65DM4: 0.016 kg
Short Engine 1275 A+ Including the following parts fitted: Pistons – Con Rods – Crankshaft – Camshaft – Cam Followers – Oil Pump – Oil Pressure Relief Valve Assembly: 53.4 kg
Standard Flywheel 7.58 kg
Spark Plugs x 4: 0.800 kg
Starter Motor Inertia 4.4 kg
Starter Motor Pre-engaged 4.5 kg
Thermostat: 0.057 kg
Timing Chain Back Plate (Alloy): 0.388 kg
Timing Chain Cover A+ with Breather: 0.621 kg
Timing Cover 1/4" Bolts, Plain & Locking Washers x 6: 0.042 kg
Timing Cover Crankshaft Oil Seal: 0.023 kg
Timing Plate: 1.000 kg
Timing Plate 5/16" Bolts & Washers x 6: 0.076 kg
Timing Plate & Cover Gaskets: 0.014 kg
Valve Spring (Single) each: 0.040 kg
Valve Spring Cap each: 0.015 kg
Valve Stem Collets x 8 Pairs: 0.016 kg
Valve Stem Seals x 4: 0.006 kg
Water Pump Bolts Flanged x 4: 0.079 kg
Water Pump Pulley 3.7/8": 0.231 kg
Water Pump Pulley 4.11/16": 0.290 kg
Water Pump (without bypass): 0.865 kg
Water Temperature Sender Switch: 0.030 kg
TRANSMISSION
Clutch Case Cover with Verto Lever: 2.100 kg
Clutch Friction Plate Verto: 0.825 kg
Clutch Lever Return Spring: 0.010 kg
Clutch Master Cylinder: 0.680 kg
Clutch Master Cylinder Clevis Pin & Split Pin: 0.008 kg
Clutch Pressure Back Plate Standard Lightened (Pre Verto): 1.978 kg
Clutch Pressure Back Plate Standard (Pre Verto): 2.600 kg*
Clutch Pressure Plate Assembly (Verto): 4.2 kg
Clutch Slave Cylinder (Pre-Verto): 0.540 kg
Clutch Shouldered Bolts Competition Long x 3: 0.064 kg
Clutch Shouldered Bolts Competition Short x 3 0.053 kg
Clutch Spring Anchor Tab: 0.005 kg
CV Joint Outer (each): 1.700 kg
Drive Flange Alloy each: 0.57 kg
Drive Flange each: 1.47 kg
Drive Shaft Nearside Short: 1.286 kg
Drive Shaft Offside Long: 1.575 kg
Flywheel (BMC 1275 Cooper S): 7.360 kg
Flywheel complete with Clutch (BMC 1275 Cooper S): 11.890 kg
Flywheel Housing (A+): 3.231 kg
Flywheel Standard Pre Verto: 7.580 kg
Flywheel Lightened Standard Pre Verto: 6.050 kg
Flywheel Bolt: 0.105 kg
Gearbox (Including all gears & differential): 26 kg approx
Gear Lever Rod Change without Gearknob: 0.651 kg
Gear Lever Kad Quickshift without Gearknob: 0.732 kg
Gear Lever Rubber Gaiter (remote change): 0.173 kg
Hub Front (with bearings fitted): 1.337 kg
Hub to Brake Disc Bolts x 4 (per side): 0.064 kg
Hub Wheel Stud Standard (each): 0.019 kg
Remote Gearchange Rear Support Bracket (Including Nuts, Bolts & Washers: 0.306 kg
Rod Gearchange Linkage (Including Support Bracket): 2.095 kg
Rod Gearchange Linkage Roll Pin: 0.003 kg
SUSPENSION
Bumpstop early two stud including Nuts & Washers (per side): 0.089 kg
Front Suspension Alloy Cone Strut Including Knuckle Joint (each): 0.295 kg
Front Suspension Bottom Arm (each): 0.840 kg
Front Suspension Bottom Arm Bushes (per side): 0.037 kg
Front Suspension Bottom Arm Pin including Nut & Washer (per side): 0.219 kg
Front Upper Arm Complete Assembly Knuckle Joint, Nuts, Bolts & Washers (each): 2.392 kg
Genuine Rubber Suspension Cone (each): 0.904 kg
Knuckle Joint (each): 0.136 kg
Radius Arm including Pin, Bush & Bearing (each): 5.089 kg
Radius Arm Fully Built Including Non Spacered Drum (each): 11.120 kg
Radius Arm Fully Built Including Spacered Drum (each): 12.500 kg
Rear Hub Alloy (Mini Sport) each: 0.419 kg
Rear Hub Nut (per side): 0.028 kg
Rear Hub Standard (not including bearings) each: 0.931 kg
Rear Hub Standard Including Bearings, Nut, Split Pin, & Cap: 1.445 kg
Rear Subframe Poly Bushes x 4 (per side): 0.042 kg
Rear Suspension Alloy Cone Strut Including Knuckle Joint (each): 0.670 kg
Rebound Buffer (per side): 0.023 kg
Shock Absorbers Front Gaz Adjustable (each): 1.416 kg
Shock Absorbers Front Standard (each): 0.818 kg
Shock Absorbers Rear Gaz Adjustable (each): 1.520 kg
Shock Absorbers Rear Standard (each): 0.650 kg
Shock Absorber to Radius Arm Nut & Washers (per side): 0.017 kg
Shock Absorber Top Mount (per side): 0.409 kg
Tie Bar Rod Heavy Duty Adjustable (each): 0.845 kg
Tie Bar Rod Standard (each): 0.498 kg
Tie Bar Rod to Bottom Arm Nut & Bolt (per side): 0.024 kg
Tie Bar Rod Front Nut & Washer (per side): 0.045 kg
STEERING
Steering Rack Retaining "U" Bolts & Nuts (pair): 0.139 kg
Steering Rack to Body Seal: 0.001 kg
Steering Column complete with Steering Wheel Nut & Steering Lock: 2.573 kg
Steering Column Pinch Bolt, Nut & Spring Washer: 0.015 kg
Steering Column Bracket (Painted): 0.090 kg
Steering Column Bracket (Chrome): 0.096 kg
Steering Column Bracket Shear Bolts & Washers (pair): 0.037 kg
Steering Column Bracket Shear Bolt Threaded Back Plate: 0.040 kg
Steering Column to Bracket Nut, Bolt & Washer: 0.034 kg
Steering Column Cowling (Mk3): 0.172 kg
Steering Rack: 3.608 kg
Steering Rack Track Rod End Locking Nut (each): 0.012 kg
Steering Wheel Retaining Nut (early): 0.044 kg
Track Rod End Long (each): 0.312 kg
Track Rod End Standard (each):
Swivel Hub Alloy (Mini Sport) each: 0.71 kg
Swivel Hub Standard with Bearings, Steering Arm & Joints (per side): 3.055kg
Swivel Hub Standard each: 1.73 kg
BRAKES
Brake Caliper Pad Split Pins x 2 (per side): 0.012 kg
Brake Drum Rear Alloy Finned Built In Spacer (each): 1.750 kg
Brake Drum Rear Non Spacered (each): 2.288 kg
Brake Drum Rear Built In Spacer (each): 3.620 kg
Brake Drum Retaining Screws Long x 2 (per side): 0.016 kg
Brake Drum Retaining Screws Short x 2 (per side): 0.006 kg
Brake Light Pressure Switch & 2 Way Union Assembly: 0.132 kg
Brake Pads 8.4" (per side): 0.302 kg
Brake Pad Clip 8.4" (per side): 0.006 kg
Brake Rear Adjuster & Tappets: (per side): 0.073
Brake Regulator Valve (Early): 0.356 kg
Brake Shoes Rear (both sides): 0.891 kg
Brake Shoe Rear Return Springs (per side): 0.048 kg
Brake Union 3 Way: 0.054 kg
Caliper Alloy Four Pot: 1.15 kg
Caliper Metro Four Pot: 3.48 kg
Caliper Two Pot 7.5": 2.66 kg
Caliper Two Pot 8.4": 3.479 kg
Caliper 8.4" Mounting Bolts & Washers (per side): 0.053 kg
Disc 8.4": 2.906 kg
Disc 8.4” Back Plate (each): 0.365 kg
Discs Vented 7.9 pair: 6.5 kg
Discs Vented 8.4 pair: 6.9 kg
Discs Rear KAD pair: 2.8 kg
Handbrake Cable Back Plate Bracket (per side): 0.074 kg
Handbrake Cable Drum Lever: 0.107 kg
Handbrake Fairlead Pad (each): 0.009 kg
Handbrake Fairlead Plate (each): 0.009 kg
Handbrake Lever (early two cable) including mounting nuts, bolts & washers: 0.780 kg
Handbrake Lever (later single cable) including mounting nuts, bolts & washers: 0.510 kg
Handbrake Lever Grip (late): 0.071 kg
Handbrake Quadrant Alloy (per side): 0.030 kg
Handbrake Quadrant (per side): 0.112 kg
Handbrake Quadrant Bolt, Nut & Washer (per side): 0.050 kg
Hub & Disc 8.4" Assembly: 4.389 kg
Master Cylinder Single (early): 0.610 kg
Rear Brake Back Plate: 0.826 kg
Rear Brake Back Plate Bolt, Nut & Washer x 3 (per side): 0.066 kg
Rear Brake Cylinder: 0.351 kg
Rear Brake Cylinder "C" Clip & Gasket (per cylinder): 0.003 kg
Rear Brake Shoes Pair (per side): 0.464 kg
MISCELLANEOUS
Fluids
Coolant Capacity: 3.5 litres = 3.5 kg
Water: 1 Pint approx 0.575 kg
Unleaded Petrol 1 Gallon (4.54 Litres) at 69 deg F (20 deg C): 3.324 kg
Fuel System
Fuel Tank 5.5 Gallon (25.0034 Litres): 4.437 kg
Fuel Tank Retaining Strap 5.5 Gallon: 0.318 kg
Locking Petrol Cap: 0.137 kg
Engine Bay
Bonnet Buffers Clubman pair: 0.015 kg
Horn Mk3 Factory Fitted: 0.775 kg
Master Cylinder Mounting Plate: 0.110 kg
Voltage Regulator Control Box: 0.427 kg
Windscreen Washer Bottle Including Electric Pump: 0.275 kg
Windscreen Washer Pipe Assembly Including "T" Piece (bulkhead mounted): 0.026 kg
Wiper Hole Blanks Stainless (pair): 0.041
Wiper Mechanism (Mk3): 0.579 kg
Wiper Motor 2 Speed (Mk3): 1.628 kg
Wiper Motor to Body Rubber Pad: 0.026 kg
Wiper Mounting Bracket Including Rubber: 0.098 kg
Interior
Accelerator Pedal (without rubber): 0.272 kg
Dash Ashtray: 0.061 kg
Door Release Rod Mechanism (each): 0.203 kg
Interior Mirror including fixing Screws (late black plastic): 0.143 kg
Pedal Box: 2.100 kg
Roll Cage Safety Devices Six Point Bolt In (Including Fixings):
Roll Cage Rear Section with Diagonal: 15 kg
Roll Cage Front Section: 10 kg
Roll Cage Dash Bar: 3 kg
Roll Cage Door Bar (Each): 2.5 kg
Seat Cobra Classic (not including Subframe) 6.1 kg
Seat Mamba Classic (not including Subframe) 6.7 kg
Seat Cross Member Front Mount (Mk3 bolt-on) Each: 0.144 kg
Seat Catch Floor Brackets (each): 0.272 kg
Sound Deadening (floor & rear quarter panels): 9.0 kg approx
Window Winder Sealant/Goo: 0.084 kg
Wheels & Outer Trim
Door Handle Chrome Mk3 (each): 0.371 kg
Front Indicator Lense Glass (each): 0.080 kg
Front Indicator Lense Plastic (each): 0.015 kg
Front Indicator Unit with Plastic Lense (each): 0.086 kg
Grille Quick Release Buttons/Fittings: 0.091 kg
Headlamp Ring Trim (each): 0.149 kg
Sill Seam Rubber Trim both sides: 0.370 kg
Washer Jets Chrome Twin Type (each): 0.019 kg
Wiper Arm Complete including Blade (each): 0.110 kg
Wiper Wheelbox Bezels Chrome Including Nuts & Seals (pair): 0.048 kg
Wheel 1275 GT Steel 10” x 4.5” (without tyre): 4.090 kg*
Wheel Cooper S Steel 10" x 3.5" (without tyre): 3.520 kg*
Wheel Cooper S Steel 10" x 4.5" with 165/70 x10" Tyre: 9.000 kg*
Wheel Cooper 12" x 4.5" with 145/60 x12" Tyre: 9.200 kg*
Wheel Nut (chrome): 0.035 kg
Wheel Minilite Alloy 10" x 5" (wheel only): 3.770 kg
Wheel Minilite Alloy 12" x 5" (wheel only): 4.570 kg
Wheel Minilite Alloy 13" x 6" (wheel only): 6.510 kg
Wheel Minilite Magnesium 10" x 6" (wheel only): 2.925 kg*
Wheel Sports Pack Alloy 13" x 6" (wheel only): 6.760 kg
Wheel Stud (each): 0.022 kg
Wheel Stud 55mm for rear brake drum with built-in spacer (each): 0.034 kg
Wheel Super Light Alloy 13" x 6" (wheel only): 5.620 kg
Wheel Super Light Alloy 13" x 7" with 175/50 x13" Tyre: 12.100 kg*
Fresh Air Ducts & Heating
Air Intake Inner Wing Duct (Mk3): 0.170 kg
Air Intake Hose to Distribution Box (Mk3): 0.180 kg
Demister Duct Left Hand Including Screws (Mk3): 0.046 kg
Demister Duct Right Hand Including Screws (Mk3): 0.057 kg
Distribution Box Including Nuts, Washers & Seal (early Mk3 without face vents): 0.249 kg
Heater Box Metal Case (Mk3): 4.4 kg
Heater Matrix (Metal): 1.226 kg
Hose Inner Wing to Heater (Mk3): 0.081 kg
Hose Heater to Demister Left Hand Duct (Mk3): 0.037 kg
Hose Heater to Demister Right Hand Duct (Mk3): 0.037 kg
Electric
Fuse Box 1976-96 (Including the 4 fuses plus 2 spares): 0.081 kg
Headlamp Bowl Inner & Rim Lamp Holder (each): 0.221 kg
Headlamp Bowl Metal (each): 0.270 kg
Indicator Switch Assembly Single Stalk (Mk3): 0.199 kg
Rear Light Unit Mk2 (Including Rubber Gasket): 0.649 kg
Wiring Loom Front Early Mk3: 1.511 kg
Wiring Loom Rear Early Mk3:
Wiring Loom Head Early Mk3 (per side): 0.075 kg
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
