It is currently Fri Jun 20, 2025 11:46 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
PostPosted: Sun Oct 11, 2015 8:54 pm
I battled with fitting new rubber boots to my indicators today.
After much swearing I figured on this process.
Figure out which way the bulb holder needs to go to screw in easily
Fit the boot over the wires.
Fit bulb holder
Fit screws thru the holder and the boot.
Fit chrome ring without lense
Screw holder to car with the ring attached to the boot.
Remove ring and fit lens
Push lens into rubber and use a small non sharp tool to tease the rubber over the chrome ring.
By screwing the holder onto the car with the chrome lens attached it flatens the rubber it to the correct postion when the lens is fitted.
By doing the above it makes fitting the lens way easier.
Good Luck
Kiwiinwgtn
PostPosted: Sun Oct 11, 2015 9:01 pm
Looks like another How To !
Didn't take photos did you
PostPosted: Sun Oct 18, 2015 1:55 pm
Fit bulb holder
Good Luck
Kiwiinwgtn
Bloody brilliant. Never has such an easy time of it doing these two lights as today, by following these instructions. Thanks!!
PostPosted: Sun Oct 18, 2015 4:18 pm
Thanks again to kiwiinwgtn for this How-To :)
