ah,,, well,,, i`d have to say that i "NEVER" like any metal moving part to be moved, (especially if it`s tightened up with any sort of pre-load) to be moved/turned etc, -->without any grease... NEVER,,, i always grease em up before i attempt anything
i hate dry metal on metal moving anything!!!!!!!!!!!! microscopic damage becomes way more than microscopic in no-time-fast.
sorry Doc, but i reckon a tad of grease isn`t going to do diddly squat to the measurement/preload setting
I say grease em all up & fit the rear seal... take the front bearing out to effect any/all adjustment,,, then fit it back in when you`re done
& yes these new-ish bearings come with a spacer that is too wide & it needs skimming
clock it in a lathe & skim a bit at a time till it`s got no play... if you take more than 2thou off at a time then you may come to grief with them ending up too tight & wearing out in no-time-fast.
if you have a "feel" for the amount of play (experienced with w/brg spacer skimming) then cool, rip off 10thou if you think it`s about right,,, but then only take 2 thou skims after that, because doin it that way makes sure you can only be 2thou pre-load at worst
sorry to butt in,,, butt i had to say to do them with grease,,, then y typing fingers went rank & started on this path to describe w/brg adjustment, sorry
move along, nothing to see here
happy easter
