It is currently Fri Jun 20, 2025 8:51 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Thu Sep 18, 2014 7:43 pm
Here's a file you may never have seen before. This one I found some years ago by chance, and thought I should sneak it away before it disappeared. The pages are mint, and so it scanned really well. The chapters are mostly the same, but specify the options which were available to these cars over standard minis, improved trim and body details. I like The Body chapter in particular for the outlines.
If you do choose to download these chapters (and you are welcome to) please do Ausmini a favor and save to your computer for your future use. It will ease the load on our server.
Enjoy!
Cover and Contents
General Data
Section A - The Engine
Section Aa - The Engine
Section B - The Ignition System
Section Ba - The Ignition System
Section C - The Cooling System
Section D - The Fuel System
Section Da - The Fuel System
Section E - The Clutch
Section F - The Transmission
Section Fa - The Automatic Transmission
Section G - The Drive Shafts
Section H - The The Rear Suspension
Section J - The Steering Gear
Section K - The Front Suspension
Section L - The Hydraulic Dampers
Section M - The Braking System
Section N - The Electrical System
Section O - The Wheels and Tyres
Section R - The Body
Section S - Service Tools
