It is currently Fri Jun 20, 2025 3:45 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Fri Feb 23, 2018 12:38 pm
You can upload images direct from your computer to the Ausmini server when you create a new thread or when replying to a post. You don't need to have the images hosted on an external image storage site like Photobucket, Imgur or Flickr.
You can’t upload images in the Quick Reply area. Instead click on the Full Editor button below the Quick Reply section.
The “Browse” button takes you to a search box to look for a photo on your computer. Select the image (jpg file format) and add some brief descriptive comments in the File comment box if you wish. These comments will appear with the photo as a title when posted.
The “Add the file” button will upload the image you select. A box will appear and it will take a few moments.
Repeat the process if you have multiple images to include in your post. Currently the maximum images per post is ten. If you have more then simply create another post with the additional images.
Next, click your cursor in the area you want to paste the photo. Select the photo file name from the frame next to the "Place inline" button (if you have uploaded multiple images use the drop-down box to see them all) and then click the “Place inline” button.
Repeat the image selection process to include multiple images in your post.
Use the Preview option to check everything is correctly placed, then Submit.
