It is currently Sat Jun 21, 2025 3:28 pm
 Post subject: Boot mounted Radiator
PostPosted: Sat Jul 30, 2005 2:40 pm
Anybody got any ideas?
What size piping would need to be used?
Seal the boot from the cabin?
Any guesses on how to plumb fresh air to it?
PostPosted: Sat Jul 30, 2005 8:26 pm
hmmm. I would love to see how someone does it..
I would think getting the air in you would have to cut the boot floor. :? withthe fans sucking the air in.. then maby do a few 3in holes along the top of the boot lid with go fast mesh in them to vent back out.. :lol:
i can see it in my head.. thats the important thing.. :wink:
Cody
PostPosted: Sat Jul 30, 2005 8:42 pm
I think the base of the boot is folded down to act as a scoop, then small vents at the rear (whether this be holes in the boot lid or boot lid not closed fully, is to get the air back out.
I've seen pics somewhere.
PostPosted: Sat Jul 30, 2005 10:57 pm
Sounds like a great idea in the wet., you would have a boot full of water,
Chris
Everything I like is either
PostPosted: Sun Jul 31, 2005 7:03 am
I know big willy has the right idea...
As far as I am aware.. they cut the boot floor away... (no scoop though)
Use big thermo fan on top side of radiator to draw air through...
& use a special bracket so you can lock boot cracked open...
Baracade
PostPosted: Sun Jul 31, 2005 6:50 pm
what about a similar thing that gets done on twinnys you know there are large vents on the side of the car at the rear and you could mount the rads against the side of the car and the fan on the opposite
check out some pics of twin engined minis
PostPosted: Sun Jul 31, 2005 7:30 pm
Bill Westerman's Twinni has holes in the boot and the boot cracked open. OK so it's a racer not a road car..
I'd louvre the boot panel then leave it shut, for a road car.... :wink:
Here's Bill's Twinni..
PostPosted: Sun Jul 31, 2005 7:31 pm
Thats what I am considering doc.. but for a while a bracket will do with it just cracked open...
Time n money you know... smiles
Baracade
PostPosted: Sun Jul 31, 2005 7:36 pm
what are the side vents for in the pic could they not work
PostPosted: Sun Jul 31, 2005 8:03 pm
They are air intakes for the motor & radiator.
PostPosted: Mon Aug 01, 2005 12:03 am
A track car would be no problem, a road car would be a bit different. Why make it a scoop when you could put it flat at the floor level and put the fans on the top surface of the radiator. A shroud could be put on the top surface with the fans in it. This should work really well. This way a seal could go around the opening which the radiator sits in and all the air would go through the core.
Chris
PostPosted: Fri Aug 12, 2005 9:11 pm
Check out www.spagweb.com
PostPosted: Fri Aug 12, 2005 9:21 pm
Where am I looking Matt? Plenty of 'stuff' to sort through.....
PostPosted: Sun Aug 14, 2005 10:30 am
http://terelius666.tripod.com/terelius6 ... /id29.html
