1415cc stroker 8V Bimmer Twinky https://ausmini.com/forums/viewtopic.php?f=23&t=94599 |
Author: | TheMiniMan [ Sun Jan 08, 2017 12:57 pm ] |
Post subject: | 1415cc stroker 8V Bimmer Twinky |
This donk is for my mums old red/white/blue ratty station wagon 1415cc, 73mm bore 84mm crank, Ground offset & hardened & balanced JP pistons (lopped tops off) 11.5:1 comp ratio, Ported & flowed Cyl head with cams ground to suit, ARP rod bolts "S" rods re-sized & narrowed to suit stroker crank Light flywheel, orange clutch, AP plate overhauld 4sync remote box with Quaife LSD lots of goodies but lots of stock stuff too we are just running the single SU carb ATM so we can check for oil & water leaks before fitting the whole thing into the car, -->once its in the car we will inject with Adaptronic ECU & all the sensors & triggers & relays & high pressure fuel pump etc ![]() ![]() ![]() ![]() ![]() ![]() Video of it running on the bench/drum here https://www.youtube.com/watch?v=xCn2zV6-x9w should be a little beauty (hopefully) can`t wait to shove it in & tune the little girl hangin for a fangin ![]() Happy New year everyone Matt |
Author: | Kennomini [ Mon Jan 09, 2017 7:41 pm ] |
Post subject: | Re: 1415cc stroker 8V Bimmer Twinky |
Looks great Matt. Question: why 8 valve and not 16? |
Author: | TheMiniMan [ Sat Jan 14, 2017 9:06 am ] |
Cheaper ![]() Also we had a spare 8v cyl head sitting here, had the stroker crank just sitting here, had a spare 73mm Bimmer-modified block just sitting here had the old 4-sync g/box from mums car,,, basically we had it all just sitting here & we wanted to test out our new single SU manifold & we wanted to test out our new 8v cam-grind so,,, it was simply a matter of "Because we can" ![]() it`s also a learning curve,,, we all need to keep learning i reckon learn something every day or it is a waste of the day |
Author: | TheMiniMan [ Wed Jan 25, 2017 9:46 am ] |
we finally got some more time to throw this little fella into the hole & get him running runs sweet as a nut & smooth as a baby`s bottom ![]() at some stage within the next few weeks we will throw all the injection stuff at it, & run him up on the dyno can`t wait ![]() ![]() cheers people Matt |
Author: | 9YaTaH [ Wed Jan 25, 2017 11:05 am ] |
Terrific stuff Matty ![]() |
