It is currently Fri Jun 20, 2025 10:06 pm
PostPosted: Mon Apr 04, 2016 11:03 am
Hi All,
I have read a number of posts but have been unable to find anyone who has done an engine conversion with a purchased subframe.
I am considering options between rebuilding the A-series or a conversion but I do not have the skills/time to build a subframe for the conversion. From a budget perspective I know the conversion will be substantially more but the idea of a more modern engine with reliable HP is tempting.
Is there anyone in Australia who will build a subframe or offers a drive in-drive out service? Have anyone used an overseas company like allspeed?
I am based in Newcastle NSW.
Sorry if this is listed somewhere.
Dean
PostPosted: Mon Apr 04, 2016 10:45 pm
I'd guess because you need to get an engineer to approve the modification and frame your using and most / all engineers will need to see the frame in the flesh. As most frames are made overseas your stuck with the prospect of ordering an expensive frame and hoping the engineer is going to like it.
Not sure how many people have taken the risk...
At the time I started there were no frames available...
Roads need more corners
PostPosted: Sat Apr 09, 2016 8:38 am
Thanks for the reply!
It seems pretty hard to find a workshop who has completed any of this, it's just a pipe dream at the moment so I'll keep reading :)
PostPosted: Sat Apr 09, 2016 8:04 pm
Hi Dean
Archangel007 (Tricky) builds frames, he's in QLD or I think Harley is still making them as well,he's in vic
Both these guys are on here
And both frames are engineered
Hope that helps
Cheers Hallsey
