gti in roundnose https://ausmini.com/forums/viewtopic.php?f=23&t=8990 |
Author: | manofaus [ Mon Jul 11, 2005 9:29 pm ] |
Post subject: | gti in roundnose |
I am looking at buying a 1987 gti suzuki. Where do most people put their radiators? Do you think I could fit it in and get it running in a month? lol... |
Author: | manofaus [ Mon Jul 11, 2005 9:42 pm ] |
also, i would like to retain the old speedo, has it been done? What sort of heater/demister will fit in the 850? |
Author: | Mini Mad [ Mon Jul 11, 2005 11:42 pm ] |
If you have enought money..sure it COULD be done in a month..but i tihnk your dreaming ![]() Again..with enough money almost anything is possible, but i havn't seen the old speedo used with an ECU, you might be able to rig up a sensor or something. If you don't want to go with the GTi instruments, you can also use something like Autometer guages.. |
Author: | IwannaMini [ Tue Jul 12, 2005 5:46 pm ] |
Mini Mad wrote: If you don't want to go with the GTi instruments, you can also use something like Autometer guages..
I would go with that suggestion. Then it would LOOK a little more original... |
Author: | blumin [ Fri Jul 15, 2005 10:43 pm ] |
Post subject: | GTI in roundnose |
Radiator in front of gearbox On the road in a month no Use mini speedo just recalobrate & use suzuki cable on gearbox end & mini on speedo head Blue[/quote] |
Author: | manofaus [ Sat Jul 16, 2005 3:14 pm ] |
how much of the inside of the engine bay will be modified? If I am not going to deseam, then perhaps I should leave the engine bay alone too. |
Author: | Chris [ Sat Jul 16, 2005 5:16 pm ] |
Post subject: | Re: GTI in roundnose |
blumin wrote: Radiator in front of gearbox [/quote]
On the road in a month no Use mini speedo just recalobrate & use suzuki cable on gearbox end & mini on speedo head Blue Go on Ron, you could do it in a month. You haven't got much on at the moment. ![]() |
Author: | cazmo [ Sat Jul 16, 2005 9:33 pm ] |
have a look here: http://www.16vminiclub.com/gallery/thum ... =61&page=2 |
