It is currently Fri Jun 20, 2025 10:15 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Thu Jun 26, 2014 8:14 pm
I'm itching to get into a race car again so I'm going to build another sports sedan hillclimb/Sprint car but to under 2 litre sports sedan specs so i can race it down the track if it's quick enough.
I'm looking at engine options (probably staying fwd as rear wheel drive would be a bit twitchy/ mental
) so I'd like everyone's opinion on the perfect motor/ gearbox to start with that's a) powerful b) affordable c) reliable and d) not a boat anchor.
This is actually happening too I'm not just talking crap
Argue away!
Sean
Potato
PostPosted: Thu Jun 26, 2014 8:41 pm
Would it be worth going light weight like a 3 cylinder of some sort. Can you use EFI or a turbo?
PostPosted: Thu Jun 26, 2014 8:49 pm
Looking at the front runners in NSW U2L IP, your choice is a Honda or Nissan, but the latter are RWD (S15 200SX/Silvia without a turbo). Honda are FWD in Civics, good gearboxes seem to be available for them. Seems like the way to go.
Otherwise a Toyota 3SG BEAMS is close, but they are not quite at the front in that class.
Good luck. Sounds like an interesting idea.
michael
PostPosted: Thu Jun 26, 2014 9:07 pm
Yeah I was leaning towards 1.8-2.0 honda but the latter is quite expensive. Yes you can run a turbo but the maximum cc is something like 1150. The new ecoboost motor came to mind which is capable apparently of 170bhp in standard trim with accessories however for it to be worth while you'd want 200+ bhp and you're kind of guessing as to how to achieve that and could be left with an expensive hand grenade
Potato
PostPosted: Thu Jun 26, 2014 9:10 pm
BMW cylinder head on a 998 mini motor?
PostPosted: Thu Jun 26, 2014 9:47 pm
Would a turboed 1000-1100cc sports bike engine fit the bill? You wouldn't expect more than 3 or 4,000 kilometres out of it, but that's a lot of racing.
PostPosted: Fri Jun 27, 2014 8:05 am
Not sure about mini engines getting one up at the 200hp mark seems difficult and expensive. No bike engines arent allowed still im pretty sure and if they were I doubt turbo ones would be. Otherwise theyd be perfect
Potato
PostPosted: Fri Jun 27, 2014 9:01 am
That makes sense. Rotaries allowed?
PostPosted: Fri Jun 27, 2014 10:18 am
Yeah but at a multiple of 1.7 or something so you can only have a tiny one
Potato
PostPosted: Fri Jun 27, 2014 11:41 am
You can't beat a busa turbo, great torque and compact, with gearbox and sequential too.
Grant
100% Pure A Series Turbo
PostPosted: Fri Jun 27, 2014 1:36 pm
Cheap thrills / easy build: G13B turbo - but it'll wreck gearboxes if you drive like a nut.
Small stock engine: 4EFTE - great power for their size.
Medium engine - b16a or 4age turbo - solid and reliable
big engine - b18a - reliable NA 200+ hp.
Other things to think about - are you buying or building a subframe? How much is cost going to influence the build? How many track days will the car see?
Or buy one of these:
http://www.ebay.com.au/itm/MINI-SPORTS- ... 1516298602
http://www.ebay.com.au/itm/MINI-SUZUKI- ... 3ce396096a
PostPosted: Fri Jun 27, 2014 2:40 pm
Harley wrote:
I was about to suggest the same. Maybe you won't get the same satisfaction as building your own but it would be an easier option.
PostPosted: Fri Jun 27, 2014 2:47 pm
The Suzuki one above would be bought for the body and engine parts only - from what I can see of that subframe I'd bin it.
PostPosted: Fri Jun 27, 2014 4:30 pm
should really of added a few extra guidelines, as i said, built to under 2 litre sports sedan rules so:
~ no turbos over 1150cc (or there abouts) so the suzuki turbo route is no go, unless de stroked but as said the boxes are weak as piss.
~ no bike engines (which is annoying because that would be the obvious winner)
the car will be a full spaceframe car probably no subframe although might make it easier to change engine types if it did, harley try and squeeze a b18 into your b16 one :P
as much as i know its easier and faster im not buying someone elses car, especially with an alloy cage. ive done that numerous times now and i want to build and develop it myself as that, although more costly, is as much a fun part of the whole thing as driving them.
sounds like b18 honda is a good option, and cheaper then a k20 although i like the way they lean back over the axle.. how are the boxes in them does anyone know?
keep the ideas coming
Potato
PostPosted: Fri Jun 27, 2014 4:46 pm
Significant difference in going full spaceframe compared to conversion subframe. Cost, build time, the lot.
Best of my knowledge - b16 and b18 engines are nearly the same - the box is, just the block is taller on the 18. Head is different but not sure how.
Users browsing this forum: rayrabbits and 17 guests
