Dose anyone want this engine for a conversion?
http://www.ebay.com.au/itm/180906332110 ... 1438.l2649
I've looked at it and spoken to the owner so if you really want it it can be brought off ebay for $500 even.
The bad news is the engine is a bit tired. The head has been rebuilt and it dose run but it has a knocking noise (seems to be from the back of the engine so may not be in the block but that's just an assumption). Their is mayonnaise in the radiator (the oil cap is clean though). The owner claims the gearbox and CV's are all rebuilt with a new clutch but I did not drive it so I can't back this up.
IMO the engine may need a full rebuild to guarantee it will last but I could be wrong. This engine should make 67 bhp on std boost (which I think is 7psi). The whole power house should only weigh around 65kg and being such a small set up fitting into a mini sub frame should be fairly easy.
If you want to buy it and your local tell me and I can get it for the $500 off ebay, I don't know if the seller will offer anyone that same deal.
If your inter state and can not pick up send me a pm and we can organize something.
I was thinking about doing the conversion that's why I looked at it but with the possable engine rebuild needed I don't have the time for that so I thought I'd let you guys know about it.
