https://ausmini.com/forums/
ENGINEERING QUESTION
https://ausmini.com/forums/viewtopic.php?f=23&t=66003
Author:  blake12345 [ Thu Sep 30, 2010 9:26 am ]
Post subject:  ENGINEERING QUESTION
HI,
WHEN DOING AN ENGINE CONVERSION DOES THE ENGINEER LOOK AT THE ACTUALLY PHYSICAL CAPACITY OF THE ENGINE? IVE BEEN OFFERED A B16 THATS BEEN STROKED NOT SURE WHAT SIZE TO BUT THOUGHT IF THEY CHECK ACTUAL CAPACITY AND NOT JUST USE THE ENGINE NUMBER, THEN ITS PROBABLY NOT WORTH BUYING IT.
OH AND SORRY FOR THE CAPS IM AT WORK AND MY CAPS IS ON ALL THE TIME
THANKS BLAKE
Author:  awdmoke [ Thu Sep 30, 2010 9:57 am ]
No, they won't be pulling the engine down to check bore & stroke (this is not WRC).
They will go with the manufacturer's specs for the engine, so you will be fine.
It is important that it has the original intake & engine managment, otherwise you will have to undergo full emissions testing.
