https://ausmini.com/forums/
Fuel pump & sender wiring 4E-FTE - help
https://ausmini.com/forums/viewtopic.php?f=23&t=65443
Author:  ade1964 [ Fri Sep 03, 2010 5:50 pm ]
Post subject:  Fuel pump & sender wiring 4E-FTE - help
Nearly at the end of my 4E-FTE conversion, need help with fuel wiring.
I have installed the complete Starlet loom.
However, somone cut the wiring plug at the fuel end.
From the main loom I have :-
1 blue -
2 yellow -
3 brown -
4 white -
5 black wires -
which seem to be for the fuel pump area,
but the wires on the starlet fuel pump are:-
1 White/Black = Earth
2 Blue/Black = Fuel pump
3 Black = Fuel pump
4 Pink = Fuel sender
5 Brown = fuel sender
I presume these just need connecting to each other.
Can somebody tell me which joins to which.
I am using a Mini tank/pump/sender, so if anyone knows this route, help would be much appreciated.
Thanks
Ade
Author:  arjay [ Fri Sep 03, 2010 6:47 pm ]
have a look at this post.
i remember seeing this awhile back so i went hunting for it for you.
http://www.ausmini.com/forums/viewtopic ... +rear+loom
Rob.
Author:  ade1964 [ Fri Sep 03, 2010 7:18 pm ]
Thank you, have spent a bit of time trying to track this down.
Thanks
