https://ausmini.com/forums/
Auto and Manual 4efte difference
https://ausmini.com/forums/viewtopic.php?f=23&t=62857
Author:  blue_deluxe [ Mon May 03, 2010 4:51 pm ]
Post subject:  Auto and Manual 4efte difference
Has anyone else used an auto engine as a base for their conversion? Just putting my observations of parts that are different when swapping a manual box onto an auto engine. I used a 6 speed manual on mine, but its the same case as a 5 speed.
-The two top gearbox mounting bolts need to be swapped to longer bolts as the manual bell housing is thicker.
-The rear gearbox mount is a different thickness, like in the picture below.
Author:  JC [ Mon May 03, 2010 5:07 pm ]
Isn't the auto box significantly larger around the driveshaft opening (in the subframe) and thus an auto is not an option in a mini?
Author:  Mini Mad [ Mon May 03, 2010 5:14 pm ]
I went the other way around and put a Manual 'box on an Auto engine..it just bolted straight up for me with no problems.
Author:  blue_deluxe [ Mon May 03, 2010 5:28 pm ]
Yeah, i got an auto car and took the block off that. Still got the auto in the shed. Bloody big lump of metal it is.
Author:  blue_deluxe [ Fri Sep 24, 2010 7:54 pm ]
Few more findings on this,
Does the auto have a diffferent starter motor mounting than a manual?
The auto one i pulled off had a bolt that went through the bellhousing and into a thread on the starter motor, and the other bolt went through the starter and into a thread on the bellhousing.
Ive swapped to a 6 speed manual, but theres no thread to bolt the starter motor onto. Anyone had this happen?
Author:  Mearcat [ Mon Sep 27, 2010 11:13 pm ]
blue_deluxe wrote:
...Does the auto have a diffferent starter motor mounting than a manual? ...
Must be - My (manual 'box) starter motor has two bolts that mount the starter motor to the bell housing, and they are both through the starter and into threads on the bell housing.
