It is currently Wed Jun 25, 2025 5:44 am
PostPosted: Tue Apr 20, 2010 1:18 pm
For the install of a 20v 2litre VTEC is it necessary to extent the front by 4 inches in a round nose? all the pre manufactured sub frames state that it is a necessity? Who knows more ?
PostPosted: Tue Apr 20, 2010 1:28 pm
Just have 4 exhausts straight out the front grill, and put a really short intake on it.
Simplify and add lightness
PostPosted: Tue Apr 20, 2010 1:55 pm
i thought the k20a motor could only be fitted to the LHD mini due the steering rack gets in the way of the diff housing MORE than the b16/18 motors
PostPosted: Tue Apr 20, 2010 6:52 pm
check this link out…
http://superfastminis.com/MT-BKIT.htm
it states here that,
"The MTB Series Subframe is compatible with all Classic Minis."
& that,
"The MTB Kit will work for Left Hand Drive Minis as well as Right Hand Drive Minis."
PostPosted: Thu Apr 22, 2010 7:21 am
& that,
The link Bill.B posted is for the B series kit. The K series kit doesnt mention LHD or RHD suitability at all.
http://superfastminis.com/MTKKIT.htm
A 2.4l K Series would be sweet if we could get one registered over here....
PostPosted: Fri Apr 23, 2010 8:10 am
The TIG
I'm quite sure you are going to have to lengthen the front for the K20. It's hard enough fitting a B-series in a left hand drive standard length Mini. You might as well just fit one midship and go RWD, it would probably be less work.
email - [email protected]
www.victoria-chiropractors.ca
