It is currently Tue Jun 24, 2025 1:02 pm
PostPosted: Fri Mar 19, 2010 4:10 pm
Does anyone know the output voltage from an electronic toyota wheel speed sender?
Is it 5V or 12V?
PostPosted: Fri Mar 19, 2010 8:52 pm
The output is a pulse not a constant DC voltage output you can measure it with a scope.
From memory mine has three wires I supplied it with a +5 volts a 0volts and the other is the output. I blew the first one up by connecting it wrong. This is for the sensor that fits in the gearbox where the normal speedo cable runs from on a starlet.
4efte powered Clubman
supercharged 998 race car
PostPosted: Sun Mar 21, 2010 10:49 am
Correct - +5VDC
PostPosted: Mon Mar 22, 2010 8:56 am
Thanks guys
