https://ausmini.com/forums/
Wheel Speed Sender Voltage
https://ausmini.com/forums/viewtopic.php?f=23&t=61878
Author:  Mini Mad [ Fri Mar 19, 2010 4:10 pm ]
Post subject:  Wheel Speed Sender Voltage
Does anyone know the output voltage from an electronic toyota wheel speed sender?
Is it 5V or 12V?
Author:  92 [ Fri Mar 19, 2010 8:52 pm ]
The output is a pulse not a constant DC voltage output you can measure it with a scope.
From memory mine has three wires I supplied it with a +5 volts a 0volts and the other is the output. I blew the first one up by connecting it wrong. This is for the sensor that fits in the gearbox where the normal speedo cable runs from on a starlet.
Author:  Archangel007 [ Sun Mar 21, 2010 10:49 am ]
Correct - +5VDC
Author:  Mini Mad [ Mon Mar 22, 2010 8:56 am ]
Thanks guys
