It is currently Tue Jun 24, 2025 7:40 pm
PostPosted: Mon Jan 18, 2010 9:50 pm
This one is for Ian on the moke forum
1330cc, 8v, turbo injected
PostPosted: Mon Jan 18, 2010 10:05 pm
Milatsmadmini
ack......
looks sex Matty....
and Ian is pretty pumped for it 8)
PostPosted: Mon Jan 18, 2010 10:12 pm
Oooh, that looks nice Matt.
A mate of mine has just bought a crashed BMW bike, so I'll be helping him build his soon (well one day).
Looks like fun!
Madmorrie.
PostPosted: Mon Jan 18, 2010 10:31 pm
Is the turbo over the clutch so you dont need to cut a bulkhead box in? Or does it give more performance over a short exhaust tract?
Btw looks fantastic.
Simplify and add lightness
PostPosted: Mon Jan 18, 2010 10:37 pm
I do 2 types of turbo exhaust manifold for the twinky-K-onversion,,,
one is short (quick-spool) road version & fits behind the donk (where the carby used to be) with no need for body mods at all,,, so no turbo box
& the other is shown in the pics, with long-equal-length stainless manifold sitting the turbo over the clutch,,, & again no body mods needed
PostPosted: Tue Jan 19, 2010 7:53 am
after seeing how snug these converted engines are in the engine bay, so hard to reconcile that with how tall they look out of the car! :D
PostPosted: Tue Jan 19, 2010 10:14 pm
now that's a innovative work bench, all round access :D
what are you running carbs or throttle bodies
www.minisprintgt.com
PostPosted: Tue Jan 19, 2010 10:48 pm
Turbo injected David,,, did you really need to ask? or was that question for everyone else ?
PostPosted: Wed Jan 20, 2010 12:18 am
It is a very nice looking donk... The new nuts and bolts is what makes it
Life's a garden.... Dig It!
PostPosted: Fri Jan 22, 2010 1:00 am
I just thought you liked those CV carbys on the small bore, and as you keep coming up with ideas a set of blow thru quads would look good. don't worry about economy just grunt
PostPosted: Fri Jan 22, 2010 1:20 am
How much did such a wicked set up set this lucky bastard back?
You're so square
Baby I don't care
PostPosted: Fri Jan 22, 2010 7:04 pm
Adam , i havn`t added it all up yet, but close to $8K-ish ,,,give or take a few million :-) ;-)
PostPosted: Fri Jan 22, 2010 8:49 pm
What's the smal brass connector above the water outlet for? :)
Very nice Matt - I want one! :)
Jan
PostPosted: Fri Jan 22, 2010 9:32 pm
Put me on the want list
PostPosted: Fri Jan 22, 2010 10:03 pm
Jan it`s a "bleed" pipe,,, the water gallery behind there is actually higher than the top hose outlet hole so i drill it out above there to bleed out any air bubbles that would get caught
the 16v isn`t as bad in that dept, so i normally only do it to the 8vs
remember that these donks originally lay down so not a problem for the bike owners... But when we fit them to mini donks & stand them upright,,,well,,, i`d rather not have any "steam" caught inside the head
Have a gork at Harrys site,,, he`s welded up the water outlet & re-machined it higher to achieve the same/similar purpose,,, much more work doing it his way tho :-) i`d like to think that i do things more cost effective achieving the same results :-) & i can use it as the thermostat by-pass at the same time :-) I`m so damn smart hey? :-) :-) :-)
& Gordo,,, one of these would be a really nice compliment to your van :-)
