Another Turbo Twinky nearly done https://ausmini.com/forums/viewtopic.php?f=23&t=60412 |
Page 1 of 2 |
Author: | TheMiniMan [ Mon Jan 18, 2010 9:50 pm ] |
Post subject: | Another Turbo Twinky nearly done |
![]() ![]() This one is for Ian on the moke forum 1330cc, 8v, turbo injected |
Author: | mattsmadmini [ Mon Jan 18, 2010 10:05 pm ] |
ack...... looks sex Matty.... and Ian is pretty pumped for it ![]() |
Author: | madmorrie [ Mon Jan 18, 2010 10:12 pm ] |
Oooh, that looks nice Matt. A mate of mine has just bought a crashed BMW bike, so I'll be helping him build his soon (well one day). Looks like fun! Madmorrie. |
Author: | blue_deluxe [ Mon Jan 18, 2010 10:31 pm ] |
Is the turbo over the clutch so you dont need to cut a bulkhead box in? Or does it give more performance over a short exhaust tract? Btw looks fantastic. |
Author: | TheMiniMan [ Mon Jan 18, 2010 10:37 pm ] |
I do 2 types of turbo exhaust manifold for the twinky-K-onversion,,, one is short (quick-spool) road version & fits behind the donk (where the carby used to be) with no need for body mods at all,,, so no turbo box & the other is shown in the pics, with long-equal-length stainless manifold sitting the turbo over the clutch,,, & again no body mods needed |
Author: | Clutch-monkey [ Tue Jan 19, 2010 7:53 am ] |
after seeing how snug these converted engines are in the engine bay, so hard to reconcile that with how tall they look out of the car! ![]() |
Author: | david rosenthal [ Tue Jan 19, 2010 10:14 pm ] |
now that's a innovative work bench, all round access ![]() what are you running carbs or throttle bodies |
Author: | TheMiniMan [ Tue Jan 19, 2010 10:48 pm ] |
Turbo injected David,,, did you really need to ask? or was that question for everyone else ? ![]() |
Author: | Gordo [ Wed Jan 20, 2010 12:18 am ] |
It is a very nice looking donk... The new nuts and bolts is what makes it |
Author: | david rosenthal [ Fri Jan 22, 2010 1:00 am ] |
TheMiniMan wrote: Turbo injected David,,, did you really need to ask? or was that question for everyone else ?
![]() I just thought you liked those CV carbys on the small bore, and as you keep coming up with ideas a set of blow thru quads would look good. don't worry about economy just grunt |
Author: | adamstuart [ Fri Jan 22, 2010 1:20 am ] |
How much did such a wicked set up set this lucky bastard back? |
Author: | TheMiniMan [ Fri Jan 22, 2010 7:04 pm ] |
Adam , i havn`t added it all up yet, but close to $8K-ish ,,,give or take a few million ![]() ![]() |
Author: | Asphalt [ Fri Jan 22, 2010 8:49 pm ] |
What's the smal brass connector above the water outlet for? ![]() Very nice Matt - I want one! ![]() Cheers, Jan |
Author: | Gordo [ Fri Jan 22, 2010 9:32 pm ] |
Put me on the want list |
Author: | TheMiniMan [ Fri Jan 22, 2010 10:03 pm ] |
Jan it`s a "bleed" pipe,,, the water gallery behind there is actually higher than the top hose outlet hole so i drill it out above there to bleed out any air bubbles that would get caught the 16v isn`t as bad in that dept, so i normally only do it to the 8vs remember that these donks originally lay down so not a problem for the bike owners... But when we fit them to mini donks & stand them upright,,,well,,, i`d rather not have any "steam" caught inside the head Have a gork at Harrys site,,, he`s welded up the water outlet & re-machined it higher to achieve the same/similar purpose,,, much more work doing it his way tho ![]() ![]() ![]() ![]() ![]() ![]() & Gordo,,, one of these would be a really nice compliment to your van ![]() |
