https://ausmini.com/forums/
Brake up grade
https://ausmini.com/forums/viewtopic.php?f=23&t=58457
Page 1 of 2
Author:  nvb34n [ Tue Nov 03, 2009 11:34 am ]
Post subject:  Brake up grade
Hi guys,
im doin a G13B conversion on my mini and im curious to as whether the Metro brakes or the swift brakes would be a better opinion for the brake up grade...
any experience and input?
cant find much information to compare here... any information on these topics would be much appriciated.
Braking power
modifications required
brake booster setup
Author:  Mini Mad [ Tue Nov 03, 2009 12:25 pm ]
Turbo or N/A?
I would stick to the mini setups personally rather than converting the swift brakes.
Metro Brakes would be more than enough or If you are really keen there are Tarox 6pot's as well as KAD 4pots, Minisport 4pots etc.
Author:  badassmini [ Tue Nov 03, 2009 12:35 pm ]
Josh where did you get your Tarox 6pot's breaks from again i can't seem to find them on the net, and if you don't mind me askin what did you pay for them.
cheers Dan
Author:  Mini Mad [ Tue Nov 03, 2009 12:43 pm ]
I contacted TAROX directly: [email protected]
The Kit was 800EUR ($1300) + $390 Shipping (2 days) 3 years ago and included:
i) Two B25 6 piston Caliper
ii) Two 235mm discs with alloy bells
iii) Two braided hoses
iv) One set of pads
v) Two adapting brackets
Author:  badassmini [ Tue Nov 03, 2009 1:05 pm ]
Cool thanks Josh i'll do that.
cheers Dan
Author:  nvb34n [ Tue Nov 03, 2009 5:37 pm ]
The conversion is goin to be N/A,
im aware the 4 pots arent a straight bolt on, is there much work involved in makin the Metros fit?
Author:  amos [ Tue Nov 03, 2009 10:00 pm ]
Do those Tarox prices include everything required to bolt on to a mini? Or is it a matter of making adaptors etc?
Author:  minstar [ Wed Nov 04, 2009 12:27 pm ]
If you have mini hubs the metros ARE a straight bolt on and if you buy a metro kit they usually supply the goodridge braided hoses including banjo (two entry points on each brake block). It is only a non straight bolt up if you are silly enough to try and adapt the metro hubs which do bad things to steering geometry, ackerman angles etc etc.
Author:  drmini in aust [ Wed Nov 04, 2009 6:45 pm ]
I fitted Josh's Tarox brakes to his swivel hubs.
The kit includes everything you need.
pics:
Note- CV split pins were put in later.
Author:  WantOne [ Wed Nov 04, 2009 6:53 pm ]
Isn't the conversion to Camira brakes pretty good for G13Bs?
Author:  Team Fancy Pants [ Wed Nov 04, 2009 7:21 pm ]
is there an easy way to tell the difference between the mini and metro hubs?
Author:  nvb34n [ Wed Nov 04, 2009 8:40 pm ]
That Tarox setup looks sweet as...
i currently have a cooper s brake setup and will need to get vented brakes, the metros sound the easiest option being straight bolt on...
will giv in vestigate into the Tarox setup :)
Author:  Gordo [ Thu Nov 05, 2009 5:52 pm ]
Metros will be cheaper and not much difference fitting them wise, prob easier to get parts for also... But the tarox are the shiz! And yeah postage was awesome, only took 2 days from payment
Author:  TheMiniMan [ Thu Nov 05, 2009 10:23 pm ]
Metro hubs have "Bolt-on" ball joints,,, mini hubs have "assemble" type ball joints
In other words, the Metros have a female thread in them where the ball joints bolt on,,, & the mini hubs have male threads where the ball joints are assembled into them
Author:  Team Fancy Pants [ Fri Nov 06, 2009 7:01 am ]
Cheers Matt, i'll have to check that when i'm home for the weekend.
Andy
