https://ausmini.com/forums/
People with 13inch RIms - Help!!!
https://ausmini.com/forums/viewtopic.php?f=23&t=57588
Author:  monda [ Sat Oct 03, 2009 4:45 pm ]
Post subject:  People with 13inch RIms - Help!!!
Hi
Also posted this in Mini Chat just incase some of you guys dont read that forum : )
Could the people with 13inch rims please let me know which brand of rims they have and width (as long as they have been legallly fitted - passed oz standards/engineered) eg. superlites etc
I require this info as I am trying to keep the front track legal i.e standard 1274mm - I can go 25mm above this in total - 1299mm as I am getting an engineers certificate.
Thanks
Author:  Slugman [ Mon Oct 05, 2009 2:20 pm ]
Dunno if it helps you or not, but you might investigate the 'Sportspack' option from England - I know they were fitted with 12" rims & sportspack arches, which I think are 3.5" wide. If it is OK to get sportspack arches as a factory extra in Pommieland, then you can probably argue that you can put them on your car here, & still be legal. :) You better talk to an engineer . . . . .
Oh, BTW - Make sure that "Standard" is actually standard for your car - Later cars had arch extensions to make them legal, so I would assume that they had a wider track too. :?
Author:  EAB [ Mon Oct 05, 2009 2:25 pm ]
well if you're talking standard width then no. unless you can get 3.5inch wide 13's with a mini pattern?
mine are 5.5 and some people on here are running up to 7" wide i think. i have sportspak flares on mine.
I doubt you could get a 13" rim that will fit (width wise) in the standard car dimensions
mine are perfomance spitfires. performance also make superlites and a few other wheels in 13" sizes, i think the thinnest they have is 4.5 and i dont know what offsets they are
