It is currently Wed Jun 25, 2025 12:16 am
PostPosted: Sat Oct 03, 2009 4:45 pm
Hi
Also posted this in Mini Chat just incase some of you guys dont read that forum : )
Could the people with 13inch rims please let me know which brand of rims they have and width (as long as they have been legallly fitted - passed oz standards/engineered) eg. superlites etc
I require this info as I am trying to keep the front track legal i.e standard 1274mm - I can go 25mm above this in total - 1299mm as I am getting an engineers certificate.
Thanks
PostPosted: Mon Oct 05, 2009 2:20 pm
Dunno if it helps you or not, but you might investigate the 'Sportspack' option from England - I know they were fitted with 12" rims & sportspack arches, which I think are 3.5" wide. If it is OK to get sportspack arches as a factory extra in Pommieland, then you can probably argue that you can put them on your car here, & still be legal. :) You better talk to an engineer . . . . .
Oh, BTW - Make sure that "Standard" is actually standard for your car - Later cars had arch extensions to make them legal, so I would assume that they had a wider track too. :?
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Mon Oct 05, 2009 2:25 pm
well if you're talking standard width then no. unless you can get 3.5inch wide 13's with a mini pattern?
mine are 5.5 and some people on here are running up to 7" wide i think. i have sportspak flares on mine.
I doubt you could get a 13" rim that will fit (width wise) in the standard car dimensions
mine are perfomance spitfires. performance also make superlites and a few other wheels in 13" sizes, i think the thinnest they have is 4.5 and i dont know what offsets they are
1962 850,Frog
