It is currently Sun Jun 22, 2025 8:32 am
PostPosted: Tue Oct 31, 2017 6:52 am
Anyone done it? If so, what coils did you end up using?
Cheers :)
PostPosted: Tue Oct 31, 2017 1:34 pm
An additional question should be : can the standard ECU handle a Coil On Plug setup and ditching the ignitor.
-Alan
PostPosted: Tue Oct 31, 2017 7:50 pm
I'm in the process of switching over to a Haltech Elite 1500, all good on that front 8)
PostPosted: Wed Nov 01, 2017 11:04 am
I personally haven't done it but it seems 2zz coils are the most popular option
PostPosted: Fri Nov 03, 2017 6:34 pm
I'm using LS1 coils...
PostPosted: Sat Nov 04, 2017 8:45 am
Was going to use them, but we found some (off a Corolla I think?) that'll fit snugly on top of the engine rather then remote mounting them, should have it all set up and running next week. Slowly making progress on the maldito El Gato... Just gotta keep telling myself it'll all be worth it in the end :roll: :lol:
PostPosted: Sun Nov 05, 2017 10:56 am
they'll probably be fine, if they have built-in igniters the Haltech will run them, otherwise you need an igniter module
