GTi Manifolds https://ausmini.com/forums/viewtopic.php?f=23&t=54033 |
Author: | WantOne [ Mon Jun 08, 2009 11:28 am ] |
Post subject: | GTi Manifolds |
http://www.treadstoneperformance.com/pr ... o+Manifold Has anyone used one of these? and do you reckon it would fit in a clubman? |
Author: | awdmoke [ Mon Jun 08, 2009 11:51 am ] |
No, haven't used one. Doubt it would fit without a serious bonnet hump, as the G13b is already quite tall in the mini bay. |
Author: | blumin [ Wed Jun 10, 2009 11:18 pm ] |
First time I've seen this manifold with top mount turbo The manifold looks like it could fit, but the turbo will probably be too high & hit the slam panel & bonnet Blue |
Author: | overdrive [ Fri Jun 12, 2009 5:28 pm ] |
blumin wrote: First time I've seen this manifold with top mount turbo
The manifold looks like it could fit, but the turbo will probably be too high & hit the slam panel & bonnet Blue Sorry to correct you, but it's not a top mount. What you can see on top is where the wastegate goes if you use one, or it can be blanked off. |
Author: | blumin [ Mon Jun 15, 2009 1:06 pm ] |
[/quote] Sorry to correct you, but it's not a top mount. What you can see on top is where the wastegate goes if you use one, or it can be blanked off.[/quote] Ummmmm, do'nt know, may not fit Blue |
