It is currently Fri Jun 27, 2025 1:53 pm
 Post subject: Starlet conversion
PostPosted: Mon Jun 08, 2009 5:39 pm
hey guys just a couple of question.. Are all year models of minis the same to do the conversion or would they be different?
Cause i dont own one (yet) i havent read alot about the engine bay specifications, would every different year model mini have a different sub frame (of course they would for the different size motors or am i wrong about this?) but what if the motors where the same would they still be different?
And which one have you found easiest to convert to the 4efte?
PostPosted: Mon Jun 08, 2009 5:48 pm
All manual minis have the same subframe and all automatic mini's have the same subframe except rover mini's their subframes are mounted slightly different using rubber mounts.
Easiest Conversion would be into a Clubman fronted mini because these have more room.
4efte powered Clubman
supercharged 998 race car
PostPosted: Mon Jun 08, 2009 5:51 pm
Go the clubman, even if you dont like the looks of it think of the extra room you get. After only working on my roundnose then getting a clubman i felt like getting binoculars out to find the engine hiding inside.
PostPosted: Mon Jun 08, 2009 6:09 pm
so the club mans are the ones with the flat front? just to clarify... if it its i like those one more than the round noses. (personal preference)
so just would it be best to get a manual or an auto.... or doesnt that matter to much?
PostPosted: Mon Jun 08, 2009 6:13 pm
Try and find a manual, as i believe the mountings are different between manual and auto subframes(very welcome to be corrected). And everyone has gone the manual subframe route before so theres more help availabke.
PostPosted: Mon Jun 08, 2009 6:53 pm
The Auto subframe is about 20-25mm wider across the mounts, moves the engine slightly forward and has more room at the front. But all the bits that make an Auto subframe unique would most likely be cut off anyway. So it really makes no difference which one you start with.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Jun 08, 2009 7:18 pm
The auto subframes here were all hydro ones. But you can stick rubber cones in them with a bit of minor butchery. Not that I would.... 8)
PostPosted: Mon Jun 08, 2009 8:06 pm
Mien
I think you and I should be friends :wink: :lol: :lol: :lol: :lol:
