Daihatsu 3 cylinder engine https://ausmini.com/forums/viewtopic.php?f=23&t=53102 |
Page 1 of 2 |
Author: | Blunder [ Mon May 11, 2009 2:01 pm ] |
Post subject: | Daihatsu 3 cylinder engine |
How many different types of 1 ltr 3 cylinder engine did they make?! I have been offered a car less the head and wondered if it was worth going to have a look?? Thanks ![]() |
Author: | 13secmini [ Mon May 11, 2009 4:59 pm ] |
Im pretty sure there are 5. Very early models had a cb23 993cc cb70 i have is twincam turbo efi, the first production car to produce 100bhp per litre and was also the fastest 1 litre production car ever made. cb60 carby cb60 turbo carby turbo diesel cb60. all 993cc |
Author: | 9YaTaH [ Mon May 11, 2009 6:34 pm ] |
13secmini wrote: Im pretty sure there are 5.
Very early models had a cb23 993cc cb70 i have is twincam turbo efi, the first production car to produce 100bhp per litre and was also the fastest 1 litre production car ever made. cb60 carby cb60 turbo carby turbo diesel cb60. all 993cc Twin Carb Turbo?? that don't sound right.... ![]() I know of and have driven (many times) the carb model...the carb model was fairly gutless (but OK!) would love to have tried the turbo. |
Author: | drmini in aust [ Mon May 11, 2009 7:23 pm ] |
They put them in Minis too (De Tomaso Innocenti Mini variety) here's pics- ![]() ![]() |
Author: | 13secmini [ Mon May 11, 2009 8:02 pm ] |
9YaTaH wrote: 13secmini wrote: Im pretty sure there are 5. Very early models had a cb23 993cc cb70 i have is twincam turbo efi, the first production car to produce 100bhp per litre and was also the fastest 1 litre production car ever made. cb60 carby cb60 turbo carby turbo diesel cb60. all 993cc Twin Carb Turbo?? that don't sound right.... ![]() I know of and have driven (many times) the carb model...the carb model was fairly gutless (but OK!) would love to have tried the turbo. Twin carb turbo? i didnt say that??? |
Author: | mattsmadmini [ Mon May 11, 2009 8:11 pm ] |
*psst.... he wrote twin- CAM* |
Author: | 9YaTaH [ Thu May 14, 2009 7:30 pm ] |
mattsmadmini wrote: *psst.... he wrote twin- CAM*
Ohhh yeah..he did ![]() ![]() |
Author: | mini-62 [ Thu May 14, 2009 11:48 pm ] |
Hi, restoring a 62 mini and putting a daihatus k3-ve2 1.3ltr on the mini box.Can you give me some ideas on what will need to be upgraded in the gearbox?l have got Quaife LSD and straight cut down gears with big bearing in idler gear.Thanks for any input ![]() |
Author: | madmorrie [ Fri May 15, 2009 10:31 am ] |
Hi, Not sure I can help you with what to replace in the mini gearbox, that was one of my reasons for doing a conversion in the first place. LSD sounds like good start though. Your conversion sounds like it deserves it's own thread, with lots of pics too. Good Luck Madmorrie |
Author: | bnicho [ Fri May 15, 2009 12:19 pm ] |
Mini-62, also intsrested to see a thread on your conversion. |
Author: | mini-62 [ Fri May 15, 2009 9:21 pm ] |
HI again, l have some photos of mini before and now but will have to get my son to show me how to put on forum. ![]() |
Author: | 9YaTaH [ Sat May 16, 2009 9:03 am ] |
mini-62 wrote: Hi, restoring a 62 mini and putting a daihatus k3-ve2 1.3ltr on the mini box.Can you give me some ideas on what will need to be upgraded in the gearbox?l have got Quaife LSD and straight cut down gears with big bearing in idler gear.Thanks for any input
![]() Mini-62...when you plonk the k3-ve2 onto a Mini box....won't you have to come up with either a chain drive or alternative drop gear set up ![]() |
Author: | mini-62 [ Sat May 16, 2009 9:24 am ] |
Hi 9yatah, The gearbox has to be cut down and a new flange welded on to suit daihatsu so all mini stuff can be used ![]() ![]() |
Author: | 9YaTaH [ Sat May 16, 2009 2:51 pm ] |
mini-62 wrote: Hi 9yatah,
The gearbox has to be cut down and a new flange welded on to suit daihatsu so all mini stuff can be used ![]() ![]() Pictures is what we will need then!! sounds like an interesting conversion ![]() |
Author: | miko [ Sat May 16, 2009 6:38 pm ] |
CB70 is an animal of an engine..... whoever does it first and sorts it out well, let me know, i'd be very interested in building one too! light, powerful and takes well to tuning.... miko |
