wallygog wrote:
I would suggest you talk to Rickman Smith at transport SA. If you read the rules here ,if the car is pre 1968 then you can do what you like to it.
that would be nice but it's just not true. you must send a modifacation proposal form to transport sa and they will send you back the details on what you have to do.in most cases it will require a engineers approval that will include lane change test brake tests ect.
the gog
With any modifications if the car is pre compliance then you do not have to build the car to suit compliance regulations as the manufacturer did not carry out testing at submit this when the car was built.
With any modification you can build a pre 68 car to what ever you want !!!!!BUT!!!! the final road worthy cert is only issued IF the car is deemed safe to drive on the road.
The point of a engineer's report is to ensure that any mods and reconstruction is is done to a standard. ie welding is done correctly and componets that are modified will take any changes in stress and load. All these mods can be "calculated" for loads and stress etc.
One issue that has come to Transport SA attention recently is the issue of torque steer on some engine transplants in minis.
Look at a Formula 1 race car, there is more" engineering" done on those than any road car, but a formula 1 is not driven down a dirt road,or driven on a highway in peak hour traffic.
Over the years the number of "mods" that I have seen done to cars that are TOTALLY un-safe is unblievable. Most of these have been done by people who are do not know what the changes are doing to the rest of the componets.
Just remember one thing, if what you do "breaks" then you or someone else may end up very dead.
www.minisprintgt.com
